Author Topic: Swing Arm Grease Nipple  (Read 1490 times)
Offline Matt_Harrington
« on: September 05, 2023, 07:28:18 PM »
Anyone have the size to hand?
The parts book has it as : (B.T6S) 96201-80000
Measured mine and it seems a strange size....
Re: Swing Arm Grease Nipple
« Reply #1 on: September 05, 2023, 07:49:35 PM »
It is a strange size and genuine are not that expensive, just remember to use a tube to hit on the flange not the end
« Reply #2 on: September 05, 2023, 11:40:37 PM »
Contact Julie as i just filled up her stock draw with them  ;)
« Reply #3 on: September 06, 2023, 09:09:54 AM »
Thanks. I'll put the old one back until I have time to make some s/steel ones - hence I was asking for the size.....
« Reply #4 on: September 06, 2023, 12:43:18 PM »
How are you going to make the internal check valve?
« Reply #5 on: September 06, 2023, 12:58:29 PM »
I have some larger threaded s/s ones and I was going to re-thread them - if that makes sense....
« Reply #6 on: September 06, 2023, 03:12:52 PM »
You're going to rethread the nipple stem or the swinging arm Matt?
Seems simpler to rethread the bolt rather than the nipple. At least then replacements are easy to find.
« Reply #7 on: September 06, 2023, 06:03:16 PM »
The originals are push in but i have drilled andctapped the bolt 6mm before now
« Reply #8 on: September 06, 2023, 06:06:41 PM »
The tread is 400 mate. Only screw type  ;)
« Reply #9 on: September 06, 2023, 06:10:16 PM »
Sorry, never look at the header just read the posts!
« Reply #10 on: September 06, 2023, 06:14:14 PM »
Have you just awoken mate  ;)
« Reply #11 on: September 06, 2023, 07:54:40 PM »
Been doin stupid hours due to idiots closing the M5 mate
« Reply #12 on: September 06, 2023, 08:04:30 PM »
Isn't that part just a normal size Matt? It's the same as the 550 swinging arm nipple and I'm sure I've replaced that with a stainless one before now. What thread pitch is it?
« Reply #13 on: September 07, 2023, 12:02:00 AM »
I can not even remember the last time i was on a Motorway. As you know Bryan, not to many in Lincolnshire  ;)
« Reply #14 on: September 07, 2023, 11:16:19 AM »
Ken, it's taper thread. It maybe M6 x 1 but I will check later when I unearth my nipple box (that just sounds wrong!) I have some identical S/steel ones but the thread is bigger so I was just contemplating modifying one .....Anyway, the old one is back where it belongs!
