Author Topic: Bike isn't recharging the battery  (Read 570 times)
Offline Athame57
    • SeaWitch Artist
« on: September 11, 2023, 05:39:55 PM »
My bike isn't recharging the battery, is the rectifier or alternator the most likely culprit?
1978 CB400F2 called Elen.
Re: Bike isn't recharging the battery
« Reply #1 on: September 11, 2023, 06:45:57 PM »
I think you can add regulator into the mix as well.
I would start by checking all the plug in connectors especially anything you might have disturbed recently such as if you have had the engine right side engine  cover off to check the rear sprocket or similar.
The wires where they come out of the alternator housing and pass eventually to the connector plug.
I assume the battery is good.
I personally would then check the voltage output at the regulator - instructions are in most manuals.
After that someone here will know about the remainder - in my brief experience it can be something simple.
« Reply #2 on: September 11, 2023, 09:13:26 PM »
What Ted said. Most times it's either a broken wire, a trapped wire or corrosion on the connectors, especially the block connectors under the l/h panel.
Reports of the wires going into the stator coil breaking off recently, check the above first, if no joy then remove the generator and check all connections inside that cover.
« Reply #3 on: September 11, 2023, 10:24:49 PM »
95% of time bad connectors, 4% of time broken wire rest bad parts
Offline Athame57
    • SeaWitch Artist
« Reply #4 on: September 23, 2023, 10:14:51 AM »
Well, did the bike shop get it right, my battery isn't going flat after all!  ;)
