Author Topic: My first project - 1974 CB360 K0  (Read 53019 times)
Re: My first project - 1974 CB360 K0
« Reply #105 on: May 12, 2024, 08:45:16 PM »
Presumably you have actually counted the teeth on the front sprocket as well or is it stamped on it?
One tooth more makes a big differance.
Does your new chain sit fully on the sprockets as it should?
Otherwise I'm stumped ???
« Last Edit: May 12, 2024, 09:23:37 PM by McCabe-Thiele (Ted) »
Offline Craizeehair
« Reply #106 on: May 12, 2024, 08:58:28 PM »
Haven’t counted the teeth on the new sprocket but it’s stamped and from DSS so presumably ok.
« Reply #107 on: May 12, 2024, 11:03:57 PM »
Count the number of teeth on the rear sprocket as well. Just because it's the original sprocket as when you got the bike doesn't mean the PO has at some point changed the sprocket and altered the gearing.
1976 Honda 400/4
1978 Honda CB400/4 'Rat' bike
Offline Craizeehair
« Reply #108 on: May 13, 2024, 04:49:52 PM »
Well…
Don’t I feel like a silly sausage!!!
I counted the teeth on both sprockets, no problem there, I made sure the wheel was pushed as far forward as it could be, no problem there, I tried the cable tie, no joy. I tried joining the links on the sprocket so as there was as little play as possibly, no joy there either.
I had pretty much given up hope, sat back on the stool and admitted defeat and just sat staring at the bloomin back wheel and stupid chain that wouldn’t fit.
That’s when I saw it, staring me in the face. I’ve heard that nobody puts baby in the corner but someone should put me in the corner, with a big pointy hat!
The chain adjuster stopper was back to front!!!
Two minutes later the chain is on and fits and looks just dandy!!
Thanks for all the suggestions,
« Reply #109 on: May 13, 2024, 06:09:31 PM »
😂😂🤭 You won’t be the first or last to do something silly! At least you’re willing to admit it too. Very satisfying to get it sorted too.
1978 Honda CB550K3.
« Reply #110 on: May 13, 2024, 07:04:55 PM »
We can all make mistakes - some are just not honest enough to own up for fear of looking foolish.
I famously rode my 400 on two cylinders on several journeys of popping & banging  as I had the plug leads on wrong.
My late father told me that the only people never make a mistakes - never do anything. ::) ::) ::)
« Last Edit: May 14, 2024, 10:22:11 AM by McCabe-Thiele (Ted) »
Offline ozzybud
« Reply #111 on: May 13, 2024, 10:08:01 PM »
I figured it was time to bite the bullet and see what carburettors are all about!! I have stripped them ready for cleaning and was feeling quite pleased with myself when I saw a small spring that I hadn’t accounted for, it’s not from the internals for sure, I’m confident it is from the hardware on the outside somewhere and I’m sure I can figure that out.
What really stumped me was the diaphragms that I ordered from NRP, I realise that I have no idea how to change them, can they be done without cutting the plastic holding rings, I’m sure they aren’t called plastic holding rings but hopefully you know what I mean!!
Not sure if you have discussed this yet?  when re-installing the slides and diaphragms into the carbs the slides need to be put in the correct orientation with the 2 holes in the bottom toward the rear of the bike. I found out the hard way! if not correct the slide will "hammer" and after less then 25 miles it was all buggered and locked up and leaned one side out. Pipe immediately turned blue.
It would have been nice if Honda put a pin and a slot like almost all the other models.
1976 Z50 YELLOW
1970 CT70 BLUE
1971 CT70H ORANGE
1972 CT70H GREEN
1973 CL200 BLUE
1975 CB360T RED
1975 CB400F BLUE
1975 CB550 ORANGE
1976 CB750F RED
« Reply #112 on: May 13, 2024, 10:43:17 PM »
You know the saying, 'The person who never made a mistake never made anything'.
Well done for finding the problem 👍
1976 Honda 400/4
Offline Craizeehair
« Reply #113 on: May 14, 2024, 07:15:44 AM »
Thank you, re the orientation of the slides, I did see a video that advised this, fingers crossed I manage to get that one right!
Offline Craizeehair
« Reply #114 on: May 23, 2024, 08:45:36 PM »
I’ve put some more bits back on the bike and am getting close to see if I can get it running for the summer.
What I did only just notice is the lever for the choke won’t drop all the way down, the lever catches on the carb body. The butterflies open and close in unison and looks ok in that respect.
Could it just be a case of bending the arm out a bit to clear the body or is there likely to be more to it?
