Author Topic: Fork Seal Removal  (Read 693 times)
Offline Phantom Rider
Fork Seal Removal
« on: September 20, 2023, 09:35:51 AM »
I'm stripping down my forks to get the stanchions re-chromed.  I'm struggling to remove the old fork seals, as I want to replace these when rebuilding the forks.  The Haynes manual, and some YouTube videos, advise that the seals are "simply pryed" out - I've tried this without success.  Are there any hints/"tricks of the trade" to remove these?  TIA
Re: Fork Seal Removal
« Reply #1 on: September 20, 2023, 10:14:33 AM »
Have you tried using one or two long thin woodscrews - screw them into the middle of seal sides then use a tool to pull them out with the screw. I'm assuming you have removed the top circlips. Use a  piece of wood to protect the fork top if you are levering against the alloy top of the leg.
« Last Edit: September 20, 2023, 10:17:51 AM by McCabe-Thiele (Ted) »
Offline Multiman
« Reply #2 on: September 20, 2023, 11:47:59 AM »
Mine were a pig to get out.
I resorted to lots of heat and then leverage, with protection for the top of the slider as Ted says.
Good luck
« Reply #3 on: September 20, 2023, 04:30:09 PM »
Also dont damage the are the outside of the seal fits on with your pry bar or you will always have a leak
Offline 400 Cafe Racer
« Reply #4 on: September 20, 2023, 04:57:22 PM »
Hi,
This tool available on Ebay
Sealey Rubber Seal Gasket O-Ring Puller Remover removal Tool - AK7000
did a super job for me on the forks and would be versatile enough for other jobs. ;)
Hope this helps.
Retired Automotive Engineer   MIMI, MITRE, DMS, MCMI.
Latest    - 1979 CB400/4  Cafe Racer - Parakeet Yellow
              - 1939 Velocette GTP 250 twin port Two stroke
1988-91 - Lamborghini Countach QV replica design and
                 build - 3000hr spare time project
In 1956 at 12yrs old and dirt tracking
              - 1937 Rudge 500 4 valve
              - 1940s Royal Enfield 225sv
              -  Ex WD Norton 500sv
« Reply #5 on: September 20, 2023, 04:59:22 PM »
Got the same type except mine Snap-On. Works well but as Bryan says be careful you don't gouge the alloy wall. I use a thin sheet of metal to protect the top of the fork.
A bit of heat works wonders too
« Reply #6 on: September 20, 2023, 07:04:10 PM »
Thanks all - much appreciated
Circlips are removed - I learnt that the hard way many years ago!
With regard to the use of heat - do you concentrate the heat onto the leg (to expand the metal), or the seal (to soften it)?
« Reply #7 on: September 20, 2023, 07:26:13 PM »
I've never needed heat but it would soften or melt the rubber part of the seal so it might be safer heating the seal than risking melting the alloy. I suspect a hair dryer on the seal would work.
« Reply #8 on: September 20, 2023, 07:33:51 PM »
Heat the alloy, don't use a naked flame or you risk blistering the lacquer, hot air gun will do. As the alloy expands it will allow the seal to pull out easier.
« Last Edit: September 22, 2023, 07:25:53 PM by Oddjob »
« Reply #9 on: September 22, 2023, 06:52:41 PM »
Success!!
Heat (from hot air gun) onto metal did the trick, and I was able to pry out the seals.
Thanks for all help - much appreciated.
Offline Matt_Harrington
« Reply #10 on: September 23, 2023, 10:00:35 AM »
Steve, that saved my withering brain any thoughts on the subject!!  ;)
