Author Topic: Didn't need a new project...but I got one!  (Read 1710 times)
Offline SumpMagnet
« on: September 22, 2023, 06:11:46 PM »
Been struggling off and on to find time to finish my 750F2 ..... and doing a load of stuff to my daily ride....and then, well..I got made an offer I couldn't refuse.
this is basivcally a family heirloom. My father bought it some 45 years ago, slowly brought it back to standard, then it got mothballed for a bit, partially pulled apart, then sort of left. He was busy renovating other folks bikes, and she got a little neglected. I was asked to give it a new home....and had to say yes.
Comes with some issues, needs cosmetics and most seriously...the distributor had been popping out, which was traced to ovalling of the crankcase opening where it sits. I have a spare set of cases, and a 500 head and barrel ( +20...but needs a rebore) Plus an assortment of other bits and pieces. 2 sets of exhausts, electrical goodies....3 boxes full!
So now I got that to play with as well!
For the record, she's a 1959 Triumph 3TA
The 500 top end is a straight swap, which is why I think Dad bought it. Gives a useful increase in performance.
Paint has a number of issues, but from a distance away...it looks pretty. And it's complete. Nearly.
https://i.imgur.com/hHkzd6K.jpg
CB750F2 - in pieces
Re: Didn't need a new project...but I got one!
« Reply #1 on: September 22, 2023, 06:18:21 PM »
That looks a nice bike - I'm sure you'll enjoy the project rebuild
« Reply #2 on: September 22, 2023, 06:21:37 PM »
Timing side mains are not good, primary chain tensioner same, worth more as a stock 350 than with 500 top end.
I would repair original case rather than change.
Slow but nice handling, brakes are yes
Offline SumpMagnet
« Reply #3 on: September 22, 2023, 08:14:27 PM »
I rode it for a few hundred miles around Wales quite a few years back. Brakes are.... no. 7" SLS. Stop faster if you put your feet down!
Primary chain tensioner is a pretty crude device, but the bottom end had all new bearings and bushings not that many miles ago. The old man is the Triumph specialist, but as I recall, it's roller bearing one side, and plain bushing the other. Hand ream and much engineers blue went into the thing. It's a foreign world to me! Full of strange bolt sizes and spanners
 If anyone knows where I could get the case repaired, I would be interested to know. It's the original motor with corect matching numbers, so even if I swap the cases to use it...I was planning on getting the originals repaired. I assume it''s a case of machining it out and putting a sleeve in, or welding up and recutting.
CB750F2 - in pieces
« Reply #4 on: September 22, 2023, 08:44:14 PM »
Yes its a case of machining and sleeving but you would need to strip the case out to do it.
You would need to find an old school engineering shop to do it, i can  think of a couple up here in gloucester(ish) but dont know London.
Rebore is relatively easy after you found piston kits
« Reply #5 on: September 22, 2023, 08:45:31 PM »
A nice looking project for those longer winter days👍.
As for the welding, I can 100% recommend a guy called Andy who runs a company called Specialist Welding.is based near Banstead. His number is: 07957 557935. He was recommended to me by SRS Engineering in Sutton, he does all their welding. I took my Triton cylinder head to him that was porous and had been subjected to really poor welding by the guy who built the engine 22 years ago. Andy did a brilliant job. I've now taken the head to Mike at SRS for blending and a surface grind.
Take the cases to Andy and he'll tell you if he can fix them. Call him first though as he does a lot of site based work.
Tell him Dave Ellis with the Dresda Triumph cylinder head sent you!
Good luck👍
1976 Honda 400/4
1978 Honda CB400/4 'Rat' bike
Offline SumpMagnet
« Reply #6 on: September 22, 2023, 08:55:50 PM »
thanks Dave, I'll sound him out and see what he says
CB750F2 - in pieces
« Reply #7 on: September 22, 2023, 09:54:48 PM »
I had a Triumph Twenty One, VRM 102 ETF, it was my first proper motorcycle after Mopeds & Scooters. I loved the clockwork speedometer but my Mum hated the oil leaks lol. That was part of the reason I bought my first Honda.
Offline SumpMagnet
« Reply #8 on: November 26, 2023, 12:23:54 PM »
I should be working on the Honda....haven;t done much to it for months....but this thing is kind of getting me hooked. If I am not careful I will be getting a flat cap, leather elbow patches and a pipe to poke at people while I tell them the shade of Polychroatic Blue on the petrol tank is all wrong for a 1947 Triumph Wombat when the total loss oil system was brought in after the Boer War.
Bike has had a total stripdown, and I am sorting out some issues with the rolling chassis before I start into the engine.
Found some of the 65 year old tinware wasn't perfect too. All sorts lurking under the paint! Nacelle top was the first thing
Holes pulled through and opened up. Welded them up and redrilled. A lot of the holes had been ovalled or slotted to make the thing fit. It's hidden under trim strips, so doesn;t show..but these had broken right through.
Fixed them all and painted it. Stuck with my Dad's choice of paint colour. Ford Cosmos Blue. Similat to the original..and ..well..it's how I remember it.
Front mudguard was next. A patch had been brazed in where the rear stay mounted. Should be a bracket rivetted to the mudguard. There was a bolt, and a horrid lashed up bracket on the inside. No. Not having that!
Ground off the braze and removed the patch. You can see what it was covering.
Chopped out the damaged area and welded a patch in. Needs cleaning up, but it's solid.
Have discovered the joy of welding 65 year old tinware. Knowing it's virtually irreplacaeble ... Did see one early front mudguard for sale. Rusty as anything...£95. One soundish one I saw went for £200. Always at the back of your mind when you blow a hole through....you aren;t going to easily find another.
So I practiced on the piece I chopped out to get the settings right, slowed it down and made tiny little stitch welds. No holes. Even in the freezing cold, I had a bit of a sweat on until it was done.
CB750F2 - in pieces
« Reply #9 on: November 27, 2023, 05:45:01 PM »
Most parts are available,  either NOS or pattern parts. Buy from the decent specialists like Tricor Andy, Draganfly or Montys Motorcycles and they should be decent quality and fit. Check part numbers for your year, lots of variations that look the same but aren't!
Good info here on the range.  https://triumph-tiger-90.com/
Offline Orcade-Ian
    • Older Vehicle Web
« Reply #10 on: November 27, 2023, 06:15:07 PM »
Hi,
Looks like another Trumpet will live to fight another day!  Excellent progress so far - ideal Winter project, it says in most adverts.  I got the job of doing the engine/box and wheels on a 'Twenty One' but the others involved have yet to complete their bits.  As it says in my web article this bike was new in 1959 in Westray - one of our outer North Isles.
http://www.stallard-engineering.co.uk/stories/other/Triumph%2021.htm
Ian
Offline SumpMagnet
« Reply #11 on: November 28, 2023, 06:51:06 PM »
Nice! I have a slight 'problem' to resolve before I can really crack on with the engine. Namely the distributor mounting hole. The thing was mothballed after it developed a nasty habit of the distributor popping out while running. This apparantly isn't good. The mounting retainer was as tight as it could be ( overtighten, and you ruin the thing... ) and that's the only thing that holds it in.
Diagnosis...an ovalled out hole in the crankcases. Allows the thing to wabble about until it loosens the locking plate and out it pops.
Need to find somewhere to get that seen to. Dad gave me a spare set of cases, but the worn set are the originals, and I would like to preserve that. The spare set also had been blasted at some point....and ALL the cracks, crevices, exposed bolt holes and so on were full of blast medium. Took me days to flush it all out. It needs new rings, as compression is a little low ( well..7:1 as standard isn;t exactly high to start with!) and there is no bore wear to speak of. Even if there is, it's on +20 barrels, so I can do that if needed. He'd also clearly been planning a 500 conversion... in the spares pile I found a 500 head, and some barrels that were still on standard bore, but in need of a rebore.
Probably not going to go that route, but they are there.
Already bought some odds and ends from Monty, needed pushrod oil seals...and he stocks the right ones for an early model. Found lots of ropey suppliers who don't specify model year.
But overall, I am enjoying playing with it.
Just a shame they hadn;t discovered metric fasteners. Or in fact ANY form of standard for threads that they would stick to for the whole bike!
CB750F2 - in pieces
« Reply #12 on: November 28, 2023, 09:23:51 PM »
It does have standard threads, Whitworth, BSF and BSC
« Reply #13 on: November 29, 2023, 08:38:10 AM »
I have a 1960 350 with 500 barrels and a distributor - they didn't use the distributor for more than a couple of years.
There are options to replace/ delete the distributor and put electronic ignition on the crank. (Although I can't currently spot any instructions for that,). Might allow you to find another way to seal an out of shape distributor hole without finding cases.
https://triumph-tiger-90.com/upgrades/
« Last Edit: November 29, 2023, 05:00:11 PM by andy120t »
