Author Topic: Battery  (Read 1441 times)
Offline Matt_Harrington
Re: Battery
« Reply #15 on: September 29, 2023, 09:35:40 AM »
Of course, if you have loads of spare cash, you could fit an Odyssy battery. They are very good but expensive. Also take up a lot less space than conventional (like most AGM batts)...
Re: Battery
« Reply #16 on: September 29, 2023, 10:13:44 AM »
I have found a bit of a problem with AGM batteries in that they are slightly taller than standard and the leads aren't quite long enough to reach. Most of my leads did fit after a bit of rerouting but on the 350 I had to replace with slightly longer leads.
I thought it may just have been Motobatt so I tried a different brand this time and that's the same. I'm told it's because they have a circuit board on top so that adds height. Never opened one up so don't know if that's true.
Offline Pauarc
Re: Battery
« Reply #17 on: September 29, 2023, 11:14:45 AM »
Hi Martin
When I lifted my cb750 engine out I made a platform just in bit higher than bike frame the put jack under engine with a piece of wood on jack and then slid it out I did it on my own but if you got help even better I left on platform to work on
Paul
Honda 90ss, Cb250k1 supper sport,
Cb400 four, CB750k7, Cb550, Cb750f2n,
Cb750k2
Re: Battery
« Reply #18 on: September 29, 2023, 11:17:04 AM »
They are truly heavy engines. Well done doing it on your own.
Re: Battery
« Reply #19 on: September 29, 2023, 11:51:19 AM »
Not sure if it applies to motor cycle batteries, on cars many but not all manufacturers specify a casing type such as Type 019 that applies to two of our vehicles. This dictates the layout & type of connection lugs, battery height, width & length in mm.
When looking for a replacement battery I search by casing type, Ah & cca I then double check the dimensions as there seems to have been a drift for selling some 019 types that are not quite the original dimensions. I suspect that manufacturers are looking to make batteries that fit a wider range of vehicles by ignoring some of the fine details.
I bought a replacement Varta battery for a BMW Mini some years ago from Eurocarparts - it was very cheap at the time compared with everything else. When I came to fit the battery it was not tall enough - it was impossible to fit the connections due to the battery location as it would have shorted on the bodywork of the battery well. I managed to make it fit by standing it on a thick peice of Polystyrene sheet. Far from ideal - the battery failed a few months out of warranty.
Below video shows AGM technology.
https://www.youtube.com/watch?v=u2QwntIO4Mk
« Last Edit: September 29, 2023, 11:57:28 AM by McCabe-Thiele (Ted) »
Re: Battery
« Reply #20 on: September 29, 2023, 12:17:29 PM »
I tend to try and find the original battery as fitted by Honda, see what's it's measurements are then see what available in replacements. In the 500/550 range the AGM batteries are 1mm taller, 161mm as opposed to the standard 160mm. I doubt 1mm would cause any problems. Width and depth are the same.
Re: Battery
« Reply #21 on: September 29, 2023, 12:20:02 PM »
All mine have been specified for the relevant bike and have been between 6 and 8mm higher.
Re: Battery
« Reply #22 on: September 29, 2023, 01:27:07 PM »
Looking at Ted's link, this associate one came up
 https://youtu.be/8CxFpIoKwy0?si=p__DBh2uaozMN8L7 interesting just to see the process.
Re: Battery
« Reply #23 on: September 29, 2023, 02:48:03 PM »
Interesting video - I have read about how to de-sulphinate lead acid batteries previously the video method looks as though it can be dangrerous.
On later smart chargers like my C-TEK there is a Reconditioning mode that they advise you only use once a year on a battery - I belive it uses pulse charging at higher voltages to reverse the effects of sulphination.
Offline Martin6
Re: Battery
« Reply #24 on: September 29, 2023, 09:05:27 PM »
Hi Martin
Paul
Neat idea. I have a couple of mates offering to lend some muscle. I'll remove the ancillaries, including the exhaust flange fixings (the parts that screw into the head). But I'll leave in the stator / dynamo, clutch etc. and see how we get on.
Your idea, plus with some 4"×2" strapped to the barrels, to lift it each side, should work. It doesn't matter if I scratch the frame getting it out, as I'm planning to strip it and paint it up. Getting it back in though...!
Offline JezzaPeach
  • CB500/4 K1 1972 gold
Re: Battery
« Reply #25 on: September 29, 2023, 09:35:52 PM »
Re the height of batteries, I think some, maybe my Motobatt AGM, (which has proved excellent) had a section that can be removed making it less tall. I didn’t spot it initially when struggling to fit it.
1972 CB500/4 K1 Gold
Wanted: my 500/4 UGP96M
from 1975-78. Garnet Brown.
Offline Jan B
  • Everything you can leave behind is a gain
Re: Battery
« Reply #26 on: September 29, 2023, 10:19:54 PM »
Very good experience with Motobatt also. Over 4 years in use without any issue. Cold storage during winter with trickle charger attached.
CB500K1
CB750K2 [project]
BMW F800GS
