Author Topic: airbox/carb and carb/manifold rubbers  (Read 1337 times)
Offline Mikep328
Re: airbox/carb and carb/manifold rubbers
« Reply #15 on: October 02, 2023, 07:27:59 AM »
In past projects I tried wintergreen oil and several other liquids/combinations that can allegedly soften old rubber.  I found that while wintergreen worked initially, a week (or less) later the rubber was a hard as it was prior to treatment.  So my experience - admittedly with "commonly available" items - was that "restoring" rubber parts  made them flexible enough to be re-attached/re-mounted but they returned rather quickly to their hardened state.
On the good side, if you don't plan to regularly remover/re-attach the particular rubber part, temporary softening might be all you need.
« Reply #16 on: October 02, 2023, 08:19:02 AM »
Parts I have softened with Reofos 50 over ten years ago are still as soft as when I forst treated them BUT that's not on a bike being exposed to fuel.
