Author Topic: Re: 41211-323-000 plate (rear sprocket cover) cleaning.  (Read 1018 times)
« on: September 30, 2023, 02:45:28 PM »
Is there an easy way to remove the coating on my rear wheel sprocket cover at home?
Not sure tbh but I think it is Chrome but could be BZP would Harpic 10 remove the coating?
« Reply #1 on: September 30, 2023, 03:11:19 PM »
Get it blasted and powder coated black. They were black on the later 550's  ;)
« Reply #2 on: September 30, 2023, 04:15:49 PM »
Harpic won't touch it ... you need something like 40% strength sulphuric acid with  a bit of glycerine added and reverse plate it at about 10 amps in that acid with lead as the other electrode .. mainly to remove the nickel under the chrome. A chrome plater will also remove by reverse plating in the chrome bath and it's fairly cheap.
« Reply #3 on: October 01, 2023, 11:33:09 AM »
What does the glycerine do Ash?
« Reply #4 on: October 01, 2023, 11:55:42 AM »
Not sure but it's what all of the platers use. Sure Google will tell you Ted.
« Reply #5 on: October 01, 2023, 12:02:12 PM »
I’ll have a look, cheers Ash
« Reply #6 on: October 01, 2023, 03:12:56 PM »
Well my sprocket plate has been in "Flow Rust Remover" overnight, it has turned Yellowish in colour as has the solution that was  pink.
« Reply #7 on: October 01, 2023, 03:27:23 PM »
you have probably just converted the chrome layer.  It's the nickel that's hard to remove.
« Reply #8 on: October 01, 2023, 04:31:10 PM »
I have managed to remove two of the dents on the flat section  but the plate is off round near the outer rim curve   & I do not have the right tools to re-shape it.
Can't powder coat in as it is but could just paint it.
Offline davidcumbria
« Reply #9 on: October 01, 2023, 04:57:21 PM »
I sprayed mine with a can of hammerite smooth gold I had knocking around. Came out great but needed a good few days on a widow sill to fully cure. Can't see that much of it once sprocket is fitted.
500/4 in 79. No bikes for 30 years. 750/4 in 2013, 550/4 in 2023. Also own  R1100GS, RD350LC YPVS , Triumph Street Triple, Yamaha XT250
« Reply #10 on: October 01, 2023, 07:08:27 PM »
Good point Dave I might do something similar.
« Reply #11 on: October 01, 2023, 10:03:50 PM »
Just not brown Ted!
« Reply #12 on: October 01, 2023, 10:04:07 PM »
…….or beige
