Author Topic: Which Points - 1977 CB400F?  (Read 836 times)
Offline SeanFD
    • Belfast-2-Belfast-By-Bike
« on: October 04, 2023, 04:58:15 PM »
Finally I have got time at "home" to work on my little 400; a restoration that started in Apr 2020 during lockdown.  :)
I have just been struggling to set the timing; I've got new Daiichi points now and the problem is that at full adjustment – plate turned fully anti-clockwise – the timing is considerably retarded. I noted that the sprung contact on 1&4 seems to move about a lot when pushed, and this just confirms the bad rep that this brand of points has.
 I have an unbranded set that came with the bike and I'm going to try these, even thought they re a little pitted, as the sprung contact seems much tighter.
I also understand that juggling the gaps to get the timing right is an option.
Meanwhile I been searching EBay and have come across some other brands I've not see before. Has anyone any experience of
FEW D-75R points:
https://www.ebay.co.uk/itm/112902907765
or FEW H41L:
https://www.ebay.co.uk/itm/115903276154
CB750 K2 - Ridden from Belfast(SA)-2-Belfast(NI)!
Re: Which Points - 1977 CB400F?
« Reply #1 on: October 04, 2023, 05:08:07 PM »
A few members have recently been buying the entire 750 points plate in order to get some decent TEC points, not 100% sure if the ones DS are selling would be suitable for the 400, which is odd as the 400 originally used the 500/550 point setup but the 500/550 used mainly 750 points and condensers and even the backplate. So in theory it should fit.
Other alternative is to find some TEC points as were originally fitted.
Offline SeanFD
« Reply #2 on: October 04, 2023, 05:57:40 PM »
I knew the points were interchangeable, but not the plate; I'll maybe look into that.
I'm scouring EBay for TEC points, which is how I came across the ones above.
For any who remember where I started a few years ago, here are a couple of pics.
I have a week to get it finished!! 🫰
« Reply #3 on: October 04, 2023, 06:16:07 PM »
Whose exhaust system is that Sean?
Offline SeanFD
« Reply #4 on: October 04, 2023, 06:25:02 PM »
It's a Motad system, Ted. I got it on eBay for £300 I think.
Offline SeanFD
« Reply #5 on: October 05, 2023, 05:29:54 PM »
So no-one has had any experience of the FEW contact breakers?
« Reply #6 on: October 05, 2023, 06:23:47 PM »
I vaguely remember using packs something like that in the 70's with no problems, at least it says  made in Japan
Offline SeanFD
« Reply #7 on: October 05, 2023, 06:29:33 PM »
Thanks Brian.
I've ordered them. According to one parts catalogue I have the numbers are for ND points; whether that is worth anything or not, of course, is moot.
