Author Topic: Valve Spring Compressor  (Read 1374 times)
Offline Martin6
« on: October 04, 2023, 05:04:53 PM »
Hi,
Can anyone recommend a suitable valve spring compressor for the SOHC CB750, please?
Also, are there any non-standard / special tools I'll need if I find I have to go deeper into the bottom of the engine?
Many thanks, Martin
Offline Pauarc
Re: Valve Spring Compressor
« Reply #1 on: October 04, 2023, 05:22:53 PM »
Martin
EBay no 363942782629 this is the one I used
Paul
Honda 90ss, Cb250k1 supper sport,
Cb400 four, CB750k7, Cb550, Cb750f2n,
Cb750k2
« Reply #2 on: October 04, 2023, 05:30:39 PM »
That's a very good price Paul.
I prefer to use the genuine Honda one myself. It speeds up the process as it has a quick release mechanism, just a flick of the toggle and the compressor unwinds completely. Saves a lot of winding etc especially when you're doing 24 valves on a CBX head.
If you can find one exactly like it cheaper that's the one I'd recommend. It's not cheap, no genuine tools are as a rule but it is quality and will last a lifetime.
https://www.davidsilverspares.co.uk/parts/by-part-number/hpart_077570010000/
Offline Martin6
« Reply #3 on: October 04, 2023, 10:29:48 PM »
Thanks guys.
Hopefully, I won't be needing these more than once a decade, so I went for the budget buy! Good to know it will fit👍.
Offline DomP
« Reply #4 on: October 04, 2023, 11:14:34 PM »
That ebay job is the one I bought, does exactly what it's intended to do cheaply.  For occasional use it's perfect.
1975 XS650B
1976 CB550F1 current project
2012 Triumph Daytona 675
« Reply #5 on: October 05, 2023, 01:09:27 AM »
Clutch nut socket, rotor puller(bolt) and circlip pliers
« Reply #6 on: October 05, 2023, 01:35:29 AM »
Small tip if your doing valves. When you get the compressor down so the collets are free, use a telescopic magnet as sold on Ebay to just suck them out. Saves them flying off and dropping down the valve springs if you try and flick them out with a small screwdriver. Then when you've removed the compressor and the valve and it's springs, use the magnet again to remove the 2 washers hiding under the springs, they tend to glue themselves in place with the oil suction. A lot of people miss these and then they drop out when your least expecting them to.
Something like this.
https://www.ebay.co.uk/itm/325391200834?hash=item4bc2d3b242:g:u9UAAOSw6RFiIdrC&amdata=enc%3AAQAIAAAAwIwaR%2FoKWgXHCOJptT5tOWeWTlJKZNj%2Fdhzx%2B6%2F9SyfZMgyZHsVifVWMeyC91jU6zs4jp9cBIol0%2FB2sB9wMT5SvNUVQZnIDoTqS9M3w861ClBudcSB2VWEpzpuWCjJ7ZkGUB%2BfQtdlE%2B9NxJLOpUrE%2FH%2FOG6a4SJN%2Fke0OpJ2tq6F%2FWv%2B3OsX92B9reSpppa4Oldiay2%2Bf9fbxbvZi2XR7ldKVAtLXs%2BcKZCRtW%2BpD4H0%2FPuql4MC38y9SXc0IgKg%3D%3D%7Ctkp%3ABk9SR-iog9TfYg
Also very handy for finding nuts/screws that fly off and land on the floor, just sweep this around and they'll stick to it as it passes over. These are a god send, can remove bolts etc that have fallen down the cam tunnel for instance.
Offline Martin6
« Reply #7 on: October 05, 2023, 07:37:33 AM »
Yes, I have one and it is worth its weight in gold!
Offline Martin6
« Reply #8 on: October 05, 2023, 07:38:43 AM »
Offline DomP
« Reply #9 on: October 05, 2023, 08:19:38 AM »
What's different about a 750 clutch nut compared to a 550?
1975 XS650B
Offline Pauarc
« Reply #10 on: October 05, 2023, 09:17:42 AM »
Martin
When you remove head you may need to order no 18 as they don’t come in all gasket set this is where you can leak oil
Paul
Cb750k2
« Reply #11 on: October 05, 2023, 12:24:40 PM »
550 clutch nut is a circlip not a nut
Offline DomP
« Reply #12 on: October 05, 2023, 01:34:38 PM »
That Bryan is a very good point!
1975 XS650B
Offline Matt_Harrington
« Reply #13 on: October 06, 2023, 09:09:35 AM »
I'd also add that a pair of fine nosed tweezers are useful for inserting the collets - with a bit of grease...
I have that ebay valve compressor and it is OK. I'd prefer the lever type but in reality it is used once in a blue moon (hopefully) and is VERY cheap.
Offline davidcumbria
« Reply #14 on: October 06, 2023, 09:12:46 AM »
I used the magnet tool for re moving collets as suggested and it worked great. No use putting them back though as they wouldn’t detach when needed. Found dangling them from a small screwdriver with grease as the adherent was the best way. Also learned that getting the spring compressed just the right amount was crucial to getting both in so the decompression worked smoothly. 8 th valve  much easier than first ! Also used the cheap compressor type above and it worked a treat.
« Last Edit: October 06, 2023, 09:14:33 AM by davidcumbria »
500/4 in 79. No bikes for 30 years. 750/4 in 2013, 550/4 in 2023. Also own  R1100GS, RD350LC YPVS , Triumph Street Triple, Yamaha XT250
