Author Topic: silicone or standard brake fluid  (Read 1166 times)
Offline mickwinf
« on: October 11, 2023, 07:45:49 PM »
Just rebuilding the caliper and master cyl on Lazarus, using red rubber grease to assemble and all new parts, the question is should I use silicone fluid, is it compatable with red grease and does it cause any problems with bleeding on our old bikes? Does it have any effect on the feel?
Re: silicone or standard brake fluid
« Reply #1 on: October 11, 2023, 08:06:18 PM »
Hi Mick, got Dot5 silicone in 550 and 750 here without any issues. Just need to make sure the system is flushed of old fluid.
1978 Honda CB550K3.
« Reply #2 on: October 11, 2023, 08:19:02 PM »
I feel that you need to get right to the outer extreme of temperature use on brake fluids to understand any significant difference in performance or feel generally. Unlikely to get even close in one of these brake system, more likely if racing.
The choices appear free to me,,without any concern really.
A point of note though, even the original Honda 750 workshop manual calls specifically for silicone grease to assemble the caliper, it's piston and seal. No alternative is given. It's the water repellent properties that give some level of protection from ingress down beside the piston area as no weather seal is in place.
Red rubber grease is vegetable oil based and doesn't, I believe,  offer the same attributes in that location. Seems more sustainable in rubber booted locations that are effectively screened from exposure directly to weather effects.
Online McCabe-Thiele (Ted)
« Reply #3 on: October 11, 2023, 08:52:58 PM »
I have silicone brake fluid in both of my bikes - aside from it not being hygroscopic it's not a paint stripper.👍👍👍
Offline mickwinf
« Reply #4 on: October 11, 2023, 11:17:58 PM »
Thanks for replies, I have only done caliper up to now with a smear of red grease around the seal would it be better to replace with silicon grease?
« Reply #5 on: October 12, 2023, 03:02:48 AM »
For the relatively small quantity I don't see it as an issue for affecting the fluids performance. An extra brake  bleed after a few weeks might ease any concerns.
« Reply #6 on: October 12, 2023, 06:53:42 AM »
There's not an incompatibility issue as far as I'm aware, its more the performance of silicone against water ingress is most effective in this location, next to water coming off the disc in wet weather. That's the only consideration and not a worry otherwise.
To give a more described picture of this:-  These caliper design have no cover in a secondary seal like  many road calipers have nowadays, with the silicone grease intended to mitigate this function from that aspect. The service interval would likely be arranged on that basis.
Any use in salty Road conditions is the ultimate concern as that provides an electrolyte to cause galvanic corrosion in the caliper bore to produce that familiar dry powder within the seal groove.
Online Bryanj
« Reply #7 on: October 12, 2023, 07:03:58 AM »
Never used any grease on calipers seals just brake fluid
« Reply #8 on: October 12, 2023, 07:13:24 AM »
I have used OKE brake DOT 5 on all my bikes for a few years now and it is great  ;)
« Reply #9 on: October 12, 2023, 07:24:21 AM »
Got confused when I looked up DOT5 and some products came up with DOT5.1 ...evidently that stuff is more like DOT3 and 4 and not silicone.
« Reply #10 on: October 12, 2023, 07:34:44 AM »
The .1 makes a big difference mate.  ;) Oke Dot 5 is good stuff.
« Reply #11 on: October 12, 2023, 09:58:06 AM »
I use Dot 5.1 in our cars as it's a good specification - iirc it's fully synthetic but miscible with older fluids such as 3.0 & 4.0.
« Reply #12 on: October 12, 2023, 10:14:20 AM »
+1 for Oke dot5. 👍
1978 Honda CB550K3.
« Reply #13 on: October 12, 2023, 11:31:45 AM »
To me it's proven in longevity, piston retracting as designed and verified over much longer period before having to work on it again. Silicone grease takes it every time for corrosion too in my experience.  I wouldn't do any caliper without it.
« Reply #14 on: October 12, 2023, 12:36:45 PM »
In the absence of a dust seal I do wonder how much seal lubricant of any kind will remain under the heat of braking.
