Author Topic: silicone or standard brake fluid  (Read 1173 times)
Re: silicone or standard brake fluid
« Reply #15 on: October 12, 2023, 01:00:46 PM »
In the absence of a dust seal I do wonder how much seal lubricant of any kind will remain under the heat of braking.
It's primarily the resistance to having water ingress Ted, very effective at that.
Unlikely with usage profile on these for the piston to have much heat transferred to it at all.
Comparable though, rear car aluminium calipers that incorporate handbrake mechanism concentric to hydraulic piston, they work perfectly with silicone grease over many years, much compromised with any corrosion effects in them. They even have protective boots, but often seem to succumb to mad jet washing practices.
Offline mickwinf
« Reply #16 on: October 12, 2023, 01:39:03 PM »
ok i think i will use silicone fluid, and clean the caliper again and use silicone grease. Thanks for help everyone.
