Author Topic: Painting my engine a few questions  (Read 1237 times)
Offline SteveW
« on: October 17, 2023, 03:30:38 PM »
Before I paint my engine with the Simoniz VHT stuff I was just wondering a few things.
Do I need any kind of etch primer first?
Is the Simoniz paint resistant to petrol, if not  can you lacquer over it?
Thanks.
1974 CB550 K0
1980 CB650
2000 CBR929RR Fireblade
1966 Lambretta LI150 Series 3
1981 RD350LC
1972 Raleigh Chopper
1974 Raleigh Tomahawk
2011 Henry Hoover
Re: Painting my engine a few questions
« Reply #1 on: October 17, 2023, 03:43:05 PM »
No etch primer needed with Simoniz VHT and once cured correctly, we find it very petrol resistant to normal everyday spills.
Offline DomP
« Reply #2 on: October 17, 2023, 06:33:15 PM »
I've just done all of my cases except the barrels, Simoniz vht goes on very nicely and covers well.  Remember to warm up your cases a bit and put the spray can in warm water for a while before spraying and you'll get a really even finish, keep at room temp or a bit higher for 24hrs before baking.
It stinks to high heavens when baking so open all windows and keep pets out!
1975 XS650B
1976 CB550F1 current project
2012 Triumph Daytona 675
Offline SteveW
« Reply #3 on: October 17, 2023, 09:04:29 PM »
Thanks Julie and Dom  :)
1974 CB550 K0
1980 CB650
1981 RD350LC
2011 Henry Hoover
Online davidcumbria
« Reply #4 on: October 17, 2023, 10:40:48 PM »
I just did mine with Simoniz and it worked pretty well. One thing I would do differently is to go over the cases and valve cover  in the high visibility areas clean up the small dings and spatter on the case surfaces with wet and dry. They seem much more noticeable when the case is resprayed.
500/4 in 79. No bikes for 30 years. 750/4 in 2013, 550/4 in 2023. Also own  R1100GS, RD350LC YPVS , Triumph Street Triple, Yamaha XT250
« Reply #5 on: October 17, 2023, 11:00:31 PM »
Yes, second that. Also, apply a mist coat and wait 20mins before applying the finish coat or two.
« Reply #6 on: October 18, 2023, 12:20:53 AM »
I'd agree with that. When you see the bare alloy of a crankcase you suddenly realise just how bad they are, a few hours spent just touching up small areas pays dividends in the end result.
I would add to make sure the cases are really clean as even the best paint job is spoiled if it doesn't stick.
Offline DomP
« Reply #7 on: October 20, 2023, 07:13:15 PM »
Agreed, I wish I had done a bit of casting clean up so mine is an 'as Honda intended' respray.
1975 XS650B
Offline H2Eric
« Reply #8 on: October 21, 2023, 12:02:29 PM »
Any thoughts on preparing the surfaces first? Vapour blasting perhaps or a jolly good scrub with Brillo pad or something similar.
« Reply #9 on: October 21, 2023, 04:12:36 PM »
I did not remove any casting marks but where the alloy had gone almost black when the paint was removed I used a Wet & Dry 180 to 400 Grit to remove the black surface so when painting the cases were pretty much bare alloy looking.
Areas that were near bolts or flanges I treated with either a small brass wire brush or a small brush wheel in my drill. I used a Thinners rag then brushed clean thinners onto the casing before painting the casings that I warmed with an electric fan heater - this seemed to help with avoiding runs. As others have said a light dusting first before applying  a second & final coat - again applying it to a warn engine casing.
It is very tempting to try to cover with the first coat, I found a light dusting helped with avoiding runs. Only in exceptional areas like the engine mounting lug areas did I need to apply a  light third layer.
« Reply #10 on: October 21, 2023, 06:06:02 PM »
Personally I vapour blasted and etch primed. Though simonizvht31d doesn’t require a primer. Great care is needed to avoid any ingress of contaminants. Alternatively go for soda blasting, but again clean, dry, clean dry and clean again. I blocked all holes and protected all bearing surfaces, but still cleaned every gallery and oil way scrupulously. Beware of the camshaft oil gallery as the alloy bungs need removing and replacing.
Offline SteveW
« Reply #11 on: October 21, 2023, 08:58:23 PM »
How easy are the bungs to remove?
1974 CB550 K0
1980 CB650
1981 RD350LC
2011 Henry Hoover
« Reply #12 on: October 21, 2023, 10:01:20 PM »
You don't need to remove the bungs, that's just being over cautious. The end tunnel is a straight line, if there was anything inside it you'd be able to see it, a thin bristle brush down the internal one until you see it come out into the straight gallery is more than sufficient. I've just blown all mine out with an airline after bead blasting the head and never had an ounce of trouble. Just make sure it's free of oil/grease beforehand and it should be fine, bung the holes up if your paranoid.
I'd advise a small forward facing wire brush in a Dremel and really get into the corners of the crankcase, that's where the oil/grease/crap is hiding, painting over that means it will just blow off later when the engines hot and after that it will just start the rest flaking.
« Reply #13 on: October 22, 2023, 08:04:27 AM »
“The end tunnel is a straight line, if there was anything inside it you'd be able to see it, a thin bristle brush down the internal one until you see it come out into the straight gallery is more than sufficient”.
Can you show us that please,Ken. I thought the only access to the cylinder head horizontal cam bearing feed gallery was via the cam shaft bearing oil feed or end bungs. I’m not sure how blast material could be seen. I’m not saying you are wrong, it’s just that I don’t understand. TBH, when I removed mine I found the gallery to be spotless.
« Last Edit: October 22, 2023, 10:46:52 AM by Sesman »
« Reply #14 on: October 22, 2023, 02:53:00 PM »
Can I show you? Not without a spare cylinder head and even then it would be difficult as the camera would need to focus real close.
However imagine the head and how it's been drilled for the oil gallery. The end gallery meets the barrels and is closed shut by the oring, that is a straight line drilling, if you hold the head up to the light I'd say you can look right down the gallery, if there was anything there blocking that gallery you'd be able to see it. A small bristle brush pushed up the gallery should clear anything inside it. The connecting gallery which runs to the inner cam journal was drilled before the bung was fitted, this crosses the vertical gallery and carries on until it's under the inner journal, Honda then drilled down from the inner journal to meet the horizontal drilling. Nothing special about that, just simple engineering. So a bristle brush pushed down that gallery from the cam journal so long as it's flexible enough will just bend around the join where the 2 drillings meet ( I'd imagine Honda smoothed out that join with a flexile reamer) it will then pass along the gallery until it meets the vertical drilling, it will then stop as it will hit the back of the bung. If you're looking up the vertical drilling you should see the end of the bristle brush. Any debris in the gallery should have been pushed into the vertical drilling by now, if so that an be pushed out easily.
That make sense?
