Author Topic: 400/4 Caliper bolts  (Read 1002 times)
Re: 400/5 Caliper bolts
« Reply #15 on: October 22, 2023, 10:40:55 AM »
I was using artistic license for comedy effect  :) being that Benelli are, as far as I  know, the first to add cylinders to a Honda engine in producing the Sei 750.
Apparently it's components can be substitute for Honda 500 items in some cases.  Piston, Rod, Gearbox, Primary drive chain etc are all a straight rip of the Honda original design.
Offline Matt_Harrington
« Reply #16 on: October 24, 2023, 04:27:29 PM »
I’ve used stainless steel bolts in this location for many years, no problems. I have found the correct bolts with the correct sized heads at Middletons.
I may get a couple but ended up buying a couple of s/h ones from 400fourbits. (which will be re-plated)
« Reply #17 on: October 24, 2023, 04:28:38 PM »
Sorry got to ask it, where did you get your 5 cylinder Honda from?
Ha! Oops.....
