Author Topic: Project CB350F  (Read 13660 times)
Re: Project CB350F
« Reply #30 on: November 25, 2023, 04:49:08 PM »
Synstryp….
Online magpie114
    • A.M. Photoblog
Re: Project CB350F
« Reply #31 on: November 25, 2023, 04:59:08 PM »
Thanks for the tip, it’s got good reviews online but there seem to be restrictions on its sale. Will try my luck next week
Honda CB350F
Honda VFR400
Suzuki 650
Re: Project CB350F
« Reply #32 on: November 26, 2023, 02:06:46 PM »
If you live near a vehicle trade paint supplier might be worth a visit wearing your dirtiest overalls - it is nasty stuff as you might be aware so ensure you wear the right safety gear.
I used Paramose Industrial bought it on e-bay last year - I just made a sort of declaration about H & S. Seller no longer on e bay as per my previous purchase they seem to move around.
https://refinishsystems.com/product/starchem-synstryp-paint-stripper-5l/?gad_source=1&gclid=CjwKCAiA9ourBhAVEiwA3L5RFpNe4xWef0tTgJdFsZIea4Zt7166Ch4EKV2pxOjfTZL4sCtlzE-4MhoCDQMQAvD_BwE
OR https://www.agwoodcare.co.uk/products/paramosewwstripper/?gad_source=1&gclid=CjwKCAiA9ourBhAVEiwA3L5RFtmyA7unIC74kQv0QpEXxSWTt6necfPiTms7JWXmatgwLiQ04WNX_xoCOYYQAvD_BwE
« Last Edit: November 26, 2023, 02:51:15 PM by McCabe-Thiele (Ted) »
Online magpie114
    • A.M. Photoblog
Re: Project CB350F
« Reply #33 on: November 26, 2023, 03:55:20 PM »
Thanks for the info, both links look good, paricularly refinish systems. I've been told of a nearby alloy wheel specialist repairer/powder coater who may have suitable stripping facilities so calling round next week. Given the health and safety aspect that would be ideal but if not then I'll try Refinish.
Honda CB350F
Honda VFR400
Suzuki 650
Online magpie114
    • A.M. Photoblog
Re: Project CB350F
« Reply #34 on: November 27, 2023, 08:33:46 PM »
Called round first thing this morning to the local car wheel repair shop on the recommendation of a neighbour. Very helpful, confirmed they had a dip tank and were willing to strip the cases which I left with them. Couldn't believe it when I got a call this afternoon to say they were ready to collect. I'm really happy, that's a big time saver. Just got to tackle that broken bolt now.
Honda CB350F
Honda VFR400
Suzuki 650
Re: Project CB350F
« Reply #35 on: November 27, 2023, 09:40:21 PM »
That's a seriously impressive turnaround time. I've been quoted THREE months by the vapour blaster I was going to use. Are you going to paint them, if you leave them bare they will corrode, ask me how I know this ::). When I restored the blue 400/4 I had the cases vapour blasted. Apparently, so I've been told, the vapour blasting process leaves a finish on the casting that protects against corrosion. I can confirm in the three years I had the 400 after the restoration the cases showed absolutely no signs of any corrosion anywhere.
1976 Honda 400/4
1978 Honda CB400/4 'Rat' bike
Online magpie114
    • A.M. Photoblog
Re: Project CB350F
« Reply #36 on: November 27, 2023, 11:01:10 PM »
I know I was pleasantly shocked. Its a small company and I might have caught them in a quiet period but he seemed very interested in what I was doing. Good point about corrosion, I'm hoping to sort out soda blasting and painting fairly soon.
Honda CB350F
Honda VFR400
Suzuki 650
Online magpie114
    • A.M. Photoblog
Re: Project CB350F
« Reply #37 on: December 10, 2023, 06:28:23 PM »
Quite a few unfinished jobs at the moment, forks and shocks are ready to assemble when I get the various bits returned from the chrome platers, probably not until end of January. Cases to paint, but I’m waiting for a warmish spell as its very cold in the garage at the moment. I’ve decided to make a start on the carbs which were filthy but underneath the oil and dirt looked reasonably ok.
Removing the float bowls revealed lots of varnish. I decided to work on the carbs in pairs and take it slowly as I’m not familiar with them. One carb (#4) came apart easily but #3 throttle slide was stuck solid and was eventually freed using lots of carb cleaner over a couple of days. Jets cleaned up ok in the ultrasonic bath. The float bowls took a bit of work to remove the last traces of varnish.
I started on #1 and #2 yesterday and both are really gummed up, throttle slides and and floats were stuck fast on both. Lots of varnish in both bowls. Interestingly, #1 was the most gummed up, decreasing progressively to #4 which was the least - probably due to how the bike was stored.
The floats freed up after a few minutes with carb cleaner but the rest will take a little more time. The float pins are stuck fast.
A number of parts will go to the platers for zinc plating this week and I’m hoping I can get them back before the holidays.
« Last Edit: December 10, 2023, 08:55:29 PM by magpie114 »
Honda CB350F
Honda VFR400
Suzuki 650
Online magpie114
    • A.M. Photoblog
Re: Project CB350F
« Reply #38 on: December 24, 2023, 02:34:01 PM »
Well the chrome plating came back to my surprise after a little over 2 weeks. I used Ashfords and the results look good. The springs aren't perfect on the insides but I fully expected that. I didn't realise that they subbed work out until I found an old thread on here. The zinc plater I've used has recommended Quality Chrome in Hull.
The carbs have cleaned up well despite the heavy varnish/tar deposits. I've retained the pilot jet, needle jet and needle but had to the replace main jet float needle + seat and fuel/airscrew with Keyster parts. I found a crack in one of the floats while setting the level so I'll have to wait until after the holidays to order a replacement and complete the assembly. Given its age I'm not going to try repairing it with epoxy.
I got one nos rear damper and paired it with the better of the two originals which has cleaned up well. I've loosely assembled the frame for the time being to save space but will need to take it apart again when I'm ready to install the engine. I'll be doing that on my own so I intend to lay the engine on its side and lower the frame over it. Unfortunately the bracket for the clocks has been powder coated in gloss black - I forgot to ask for it in satin black.
The fork stanchions were derusted using Evaporust, I'm really surprised they are only partially chrome plated. Will assemble them after the Christmas period...can't see me getting much garage time until then.
Honda CB350F
Honda VFR400
Suzuki 650
Re: Project CB350F
« Reply #39 on: December 24, 2023, 09:43:26 PM »
Lovely working there. Look at that shiny bits! Great to see it coming together too.
1978 Honda CB550K3.
Online magpie114
    • A.M. Photoblog
Re: Project CB350F
« Reply #40 on: December 28, 2023, 08:55:59 PM »
I’ve been putting off tackling the broken sump bolt, convinced that it was likely to be in tight and develop into a saga and I’d damage the case. It was in a blind hole and I was worried that the bolt had bottomed out before snapping. However using a left hand drill it was out in under a minute! I’ve used stud extractors before but this is the first time I’ve used a left hand drill - handy bit of kit.
So my new years resolution is to concentrate solely on preparing and painting the cases. I can then assemble and install the bottom end. The garage is pretty cold at the moment and there’s no sign of the weather improving for some time so I’m thinking of knocking together some sort of paint enclosure which I can heat.
Honda CB350F
Honda VFR400
Suzuki 650
Re: Project CB350F
« Reply #41 on: December 29, 2023, 08:14:50 AM »
Very satisfying when it comes out that easy. I bought a cheap tent to erect in the garage makes a nice space easy to heat and can be dismantled afterwards.
1978 Honda CB550K3.
Re: Project CB350F
« Reply #42 on: December 29, 2023, 08:28:25 AM »
That's an excellent idea Johhny and a Top-Tip. It saves all the hassle of trying to put up sheets of plastic that blow around when the door is open for ventilation and having a base will also prevent dust being raised from the floor.
1976 Honda 400/4
Online magpie114
    • A.M. Photoblog
Re: Project CB350F
« Reply #43 on: December 29, 2023, 08:52:43 AM »
Great idea. I was going to cobble up a frame and plastic sheets. I’ll give this a go.
Honda CB350F
Honda VFR400
Suzuki 650
Re: Project CB350F
« Reply #44 on: December 29, 2023, 11:34:14 AM »
I've used a gazebo with sides before. Worked well, but doesn't have a floor/groundsheet, of course.
