Author Topic: Project CB350F  (Read 55018 times)
Offline magpie114
    • A.M. Photoblog
Re: Project CB350F
« Reply #75 on: May 11, 2024, 12:01:10 PM »
No its plain on the other side. If I mount it the other way round it would be slightly out of line and the peg wouldn't be restrained when tightening or undoing its nut.
David Silver have 50 on order and will let me know the ETA on Monday. On the photo from the DS site you can see how the peg would sit correctly on the sprocket. Still got a lots to be getting on with so I can wait.
Honda CB350F
Honda VFR400
Suzuki 650
Offline magpie114
    • A.M. Photoblog
Re: Project CB350F
« Reply #76 on: May 16, 2024, 08:03:00 PM »
Finally got the correct rear sprocket, tried all the usual places but I had overlooked Honda Classics. Looking for a stainless f/brake caliper piston and a couple of other items I typed CB350f in the site search bar and there amongst the parts was the sprocket. Ordered online Tuesday evening, delivered Thursday morning and the pegs fit correctly.
I’ve been checking the placement of the various washers on the brake stay arm. The rubber washer had previously been fitted (apparently incorrectly) on the outside of the stay instead of next to the brake plate. Confusingly the owners manual shows it on the outside.
Also I initially thought the parts diagram of the stay at the swing arm was wrong - shouldered bolt, torque arm, 10mm spring washer, 8mm plain washer then nut. However I suppose this allows some movement of the arm whilst retaining some tension.
Honda CB350F
Honda VFR400
Suzuki 650
Re: Project CB350F
« Reply #77 on: May 16, 2024, 08:15:29 PM »
You should find the spring washer will fit over the plain shank of the bolt but the plain washer will not
Offline magpie114
    • A.M. Photoblog
Re: Project CB350F
« Reply #78 on: May 21, 2024, 09:51:34 PM »
I’ve been scratching my head over the ignition timing. Just couldn’t make sense of it, going round in circles trying to find what I’d done wrong. Almost like the advancer was 180 degrees out, but didn’t think it could be as there’s a locating peg. Then a quick search on here confirmed that the cam could be reassembled incorrectly. Images of the advancer online show the mark on the rim facing the semi circular alignment notch whereas mine faces away.
My efforts to free up the original f/brake master cylinder, which was gummed up and is still stuck fast, have so far been unsuccessful. I’ve cleaned it externally and soaked it in penetrating oil but had no joy. As I’m unsure whether it will be too badly corroded if I do eventually manage to free it I got a good master cylinder without internals from 400fourbits and used the repair kit I got for the original.
I’m still searching for a lower German or French handlebars so I’m reluctant to get throttle cables and the top brake hose until I’ve exhausted all avenues and know which bars I’ll be using.
Honda CB350F
Honda VFR400
Suzuki 650
