Author Topic: 400/4 Cam Chain tensioner.  (Read 1074 times)
Offline ComfySofa
« on: October 29, 2023, 11:57:34 AM »
Having a clear up since the rebuild. While the motor was apart i changed the CamChain tensioner for one of those billet alloy ones. Apparently the OEM ones are still worth something. If anyone is interested in mine...30 quid delivered. Its hardly done any miles... (6200) so apparently Bryan tells me theres loads of life left in it yet!
Re: 400/4 Cam Chain tensioner.
« Reply #1 on: October 29, 2023, 12:14:17 PM »
I can confirm it was like new when i built the engine
Online SteveW
« Reply #2 on: October 29, 2023, 12:26:55 PM »
Are there alloy ones available for other models?
Just in the process of stripping down my 550, haven’t closely examined my tensioner yet but I know replacements from DS are £££.
1974 CB550 K0
1980 CB650
2000 CBR929RR Fireblade
1966 Lambretta LI150 Series 3
1981 RD350LC
1972 Raleigh Chopper
1974 Raleigh Tomahawk
2011 Henry Hoover
« Reply #3 on: October 29, 2023, 12:33:33 PM »
Nope, only the 400 horseshoe(does fit the 250/360 G5 i think). As an aside the 500/550 main part is very robust unless messed with
Online SteveW
« Reply #4 on: October 29, 2023, 12:51:26 PM »
Thanks Bryan, I’ll check the condition of mine tomorrow.
1974 CB550 K0
1980 CB650
1981 RD350LC
2011 Henry Hoover
« Reply #5 on: October 29, 2023, 09:11:08 PM »
I too looked at the not inexpensive alloy type tensioner when rebuilding my 400. It appears that the original type just seizes up through lack of being moved/adjusted during servicing. Mine freed off quite easily so I did not replace it.
Not convinced that for all the difference in construction  the pivot would not still gum up over time. Be interesting to read/see the evidence of how the alloy design stands up over time.
That said it does look a nicely engineered part.
« Last Edit: October 29, 2023, 09:13:05 PM by McCabe-Thiele (Ted) »
« Reply #6 on: October 29, 2023, 11:22:43 PM »
Ted, i think it was more that Honda discontinued the original steel one which gets battered by the camchain if left loose and that burred the pivot pins, siezing it solid
« Reply #7 on: October 29, 2023, 11:43:56 PM »
Will an alloy horseshoe stand up any better to such battering as the steel original Bryan or is it just a case of there is now no alternative?
« Reply #8 on: October 30, 2023, 07:02:55 AM »
It was developed by TTR400 on this forum who does lots of 400 goodies so i would hope so but also yes its the only one
« Reply #9 on: October 30, 2023, 08:32:55 AM »
As Bryan says, Kevin, TTR400 designed and manufactures them. Kevin rides all around the world on his 400/4, covering thousands of miles, so the product is well tried and tested. I know Kevin sells his products via David Silver and 4 into 1 in USA so I bet there is a huge number of his cam horseshoes in use around the world.
« Last Edit: October 30, 2023, 08:36:35 AM by Nurse Julie »
« Reply #10 on: October 30, 2023, 11:43:19 AM »
I believe its likely victim of oil from that period getting quite sticky, tar like when subjected to high heat range that's present. It's seen in the twins too from crankshaft oil ways clogged with carbonised oil centrifuged into it's nooks and crannies.
Oils are all, I believe, better currently. But one area that synthetic easily outperforms traditional blends.
