Author Topic: speedo packing  (Read 6676 times)
Offline mo goldie
speedo packing
« on: October 30, 2023, 12:58:02 AM »
Hi
Do anyone know where to get a speedo packing think part No is 14201-37242-283-000
as someone has just put the thin rubber gasket and the speedo rides up all the time.
Cheers Mo
Currant BIKES:
1980 Triumph Bonneville 750 T140/D Special Black & Gold
1962 BSA 650 Rocket Gold Star ( silver )
1977 Norton Commando 850 MK3  Interstate ( silver )
1977 Kawasaki KH400 Triple ( Green )
1999 Harley Davidson 1200S sportster Sport ( silver )
1975 Honda Monkey st70 Dax ( Blue )
1967 Honda CB450 KO Black Bomber
Re: speedo packing
« Reply #1 on: October 30, 2023, 04:05:02 AM »
No such number, should be 5 numbers, then 3, then another 3.
Re: speedo packing
« Reply #2 on: October 30, 2023, 08:16:25 AM »
37242-283-000
Out of stock here but look at the price !
 https://www.nospartsnow.com/nos-honda-cb160-cb450-cl160-cl175-speedometer-rubber-gasket-37242-283-000/
Real hens tooth item. CB160 one will fit I believe.
Maybe fabricate something with single sided adhesive foam rubber.
« Last Edit: October 30, 2023, 08:22:55 AM by AshimotoK0 »
Re: speedo packing
« Reply #3 on: October 30, 2023, 02:13:54 PM »
Maybe get a bigger one of say a 500 or 550 and cut and join it.
Re: speedo packing
« Reply #4 on: October 30, 2023, 04:49:27 PM »
Isnt the early 450 an oval unit with both clocks in it Ken, later one used clocks same as 500
Re: speedo packing
« Reply #5 on: October 30, 2023, 05:01:24 PM »
I think what he means is try using the foam off a late large 550 clock by cutting it and forming an oval one Bryan. Which is a good idea if it works.
Offline mo goldie
Re: speedo packing
« Reply #6 on: October 30, 2023, 06:59:34 PM »
well what can I say..... I did not want to buy the whole clock Assy  ;D
I have sorted it out now made myself one out of some old BSA foam used on the oil box, looks like the Honda one.
and yes the Bomber has the clocks all in the oval unit.
Mo
Currant BIKES:
