Author Topic: M10 DOME Cylinder NUTS HEX  (Read 21853 times)
Re: M10 DOME Cylinder NUTS HEX
« Reply #75 on: November 13, 2023, 09:25:24 PM »
Well done private investigator Mo  ;D
Great youve got it sorted out.
« Reply #76 on: November 13, 2023, 11:42:03 PM »
So pleased you now have in your possession Mo.
Sorry for the hassle you had getting it delivered.
« Last Edit: November 14, 2023, 07:06:25 AM by AshimotoK0 »
« Reply #77 on: November 14, 2023, 03:46:10 AM »
I'd have asked why they hadn't come round with it when they knew it wasn't theirs.
Offline mo goldie
« Reply #78 on: November 14, 2023, 06:41:49 PM »
well I did ask her why she said she been Busy.......... I wanted to say so have I but still found the time to do the running around to get it tho........ and twice too.
But all good Now........ Thanks again everyone for all the help and Thanks ashley for selling it to me  8)
Cheers a happy mo  ;D
Currant BIKES:
1980 Triumph Bonneville 750 T140/D Special Black & Gold
1962 BSA 650 Rocket Gold Star ( silver )
1977 Norton Commando 850 MK3  Interstate ( silver )
1977 Kawasaki KH400 Triple ( Green )
1999 Harley Davidson 1200S sportster Sport ( silver )
1975 Honda Monkey st70 Dax ( Blue )
1967 Honda CB450 KO Black Bomber
Offline mo goldie
« Reply #79 on: November 15, 2023, 11:53:19 PM »
Hi Guy`s
Just an update on the Bomber, well the parts came from Dave silver so I made a start this morning took off the rear Mudguard and the rear wheel and got the shaft out only to find there was Not much Grease in it what so ever, anyway the bushes looked ok so I done what Ashely said and the New old stock Collar fitted in a treat with No worries. so put all new parts in ( so got a new set of bushes for spare ) fitted it back in the frame and there is No Movement from side to side Now so all good,
and the up and down is nice and smooth too. I found out also that the Grease Nipple was Not letting any grease go in though the shaft so heated that up with a blow lamp and cleared that all out just need to force some more in to make sure that the cavity is all full up unlike it was so must have been why it got worn in such a shout time as was only done about 3 1/2 years ago so the bloke said who i got it off.  and it had only done 1,500 miles....... but ha Ho all done now.
Happy man
Mo
Currant BIKES:
« Reply #80 on: November 16, 2023, 01:07:59 AM »
The book says grease every 1500, i say grease every journey
« Reply #81 on: November 16, 2023, 09:35:16 AM »
We discussed on another thread about lubricant, specifically grease type with some consideration to use a black molly CV type grease in these.
I'd favour that as properties of very high resistance to pressure and normally sited in limited use / movement type joints.
May want to consider this, I use it also for headstock bearings. Highly resistant to being displaced and hugely repellant to moisture etc.
« Reply #82 on: November 16, 2023, 02:42:18 PM »
I prefer MolyD for those locations as well Nigel.
Offline mo goldie
« Reply #83 on: November 16, 2023, 11:29:32 PM »
are ok
what do you use in the Engine of a Black Bomber or should I say what's the best to use......... if there is such a thing Now ?
Currant BIKES:
« Reply #84 on: November 17, 2023, 08:10:50 AM »
are ok
I feel there's good evidence (significant thread of discussion on here) to use a modern synthetic in these engine.
Concerns about camshaft longevity, supply to that location and the heat with consequent "clagging" in the high heat crankshaft oil passages, then coupled with oil pump type, all have the potential to be helped by one of these oil types.
No its not because its more slippery, but much more about consistency of viscosity and pace of flow given the architecture within it, that's in my view  :)
Offline cbxman
« Reply #85 on: November 17, 2023, 08:55:22 AM »
are ok
Nigel,
Interesting about the oil....although this tread is in danger of massive drift!
Do the 250/350/360 engines fall into this synthetic oil category that you are suggesting.  They are very similar as I understand.  Can you pint me to the thread please.
Jerry
CB750 K1 1971 Wisconsin, USA
Suzuki GT550 J 1972 Michigan USA
CB360 G5 1975 UK
CBX1000 A 1980 (European Direct Sales)
CB1300 A5, 2005 UK
« Reply #86 on: November 17, 2023, 09:06:23 AM »
It's this one Jerry http://www.sohc.co.uk/index.php/topic,14515.0.html there's some intriguing and very in depth record from Jensen in running his 450 over extended period.
I do think the twins generally are in the same category with regard to oil, yes.
« Reply #87 on: November 17, 2023, 09:29:28 AM »
Probably because early twins were all roller big ends not shells
Offline cbxman
« Reply #88 on: November 17, 2023, 11:49:35 AM »
Nigel,
That was a long read and some of the stuff went in, but some went through!
The thread is quite old from 2017.  Just wonder what the outcome was....or did I miss a link.
I do know that when I tried a 10/40 on my CBX many years ago.  I had to drain it fairly quickly as to use someone's quote, it was making a bid for freedom out of every seal/gasket.  Returned to dino and it all dried up.  Some comment on using it with new seals and gaskets only makes sense on rebuild though.
Cheers,
Jerry
CB360 G5 1975 UK
CB1300 A5, 2005 UK
« Reply #89 on: November 17, 2023, 02:11:37 PM »
"Returned to Dino" Love that quote, so descriptive.
Lots of comments about leakage using fully synth in old machinery, semi less leakage but is it worth the risk? Might as well stay with Dino oil until it's not practical anymore IMO.
