Author Topic: Points advance unit  (Read 1480 times)
Offline Mikep328
Re: Points advance unit
« Reply #15 on: November 12, 2023, 04:09:47 PM »
just curious, are all the CB four cylinder points plates/advance units the same from that era?  IOW, can the 400/550/750 components be interchanged?  Pics look the same to me...
« Reply #16 on: November 12, 2023, 04:27:58 PM »
Points plates yes, advancers will vary on advance curve but will physicaly fit
Offline Matt_Harrington
« Reply #17 on: November 12, 2023, 05:53:00 PM »
Bryan , when you say advancers, does that mean the cam AND the weights/springs?
« Reply #18 on: November 12, 2023, 06:24:47 PM »
Yes the complete unit, inadvisable to swap parts between advance units
Offline Mikep328
« Reply #19 on: December 05, 2023, 04:04:51 AM »
Does the points cam index mark on an ND advance unit point to the 1-4 or the 2-3 markings? (it can be assembled either way so wondering which is correct.)
« Reply #20 on: December 05, 2023, 09:19:51 AM »
There's some really good images on here of the correct position.....but I can't readily find them.
It won't run if fitted backwards...giving crude analysis to confirm  :)
Finding out...install it however fitted, turn the crank to F on 1&4 (as that's indexed to crank) the cam should now be starting ramp to lift points of 1&4 set to fire those piston at the top of stroke.
The other, wrong way, it will be just starting to lift 2&3 with those piston at the bottom of stroke.
Offline ka-ja
  • ken
  • yoshi 460
« Reply #21 on: December 05, 2023, 10:18:35 AM »
here you go, cam position notch
« Last Edit: December 05, 2023, 10:20:15 AM by ka-ja »
nice bike,nothing in the bank
Offline Mikep328
« Reply #22 on: December 05, 2023, 12:47:09 PM »
Thanks!  I had found some images of the TEC unit and ASSumed it would be the same but wanted to be sure.  The pics I found of the ND were too low resolution/grainy to see, including those in the service manual.
