Author Topic: Plating springs  (Read 1213 times)
Offline DomP
Plating springs
« on: November 19, 2023, 10:10:31 AM »
I'm doing as much plating of all parts on mymy CB550 as I can while I'm working my way through the rebuilding process, is there a way to replate springs that will get the plating onto the contacting coils?  I presume they would have been made from preplated wire originally.
1975 XS650B
1976 CB550F1 current project
2012 Triumph Daytona 675
Re: Plating springs
« Reply #1 on: November 19, 2023, 10:29:29 AM »
I would imagine if you could prop something in the spring to extend it slightly you would get between the coils?
1978 Honda CB550K3.
Offline DomP
Re: Plating springs
« Reply #2 on: November 19, 2023, 11:15:27 AM »
I thought I could do something similar by putting wire between the coils to open them up
1975 XS650B
Offline Orcade-Ian
    • Older Vehicle Web
Re: Plating springs
« Reply #3 on: November 19, 2023, 12:00:02 PM »
Presumably you are talking about side, centre stand and pedal springs?  I've replated quite a few and they come out well closed up but if you are really concerned about plating in almost non existent gaps between coils you could use a pice of 1/2" ply  with a window cutout for the spring body and attach one end to the ply with a screw and then stretch very slightly and secure the other end. Perhaps capillary action takes the zinc ions into the gaps without the need for stretching?  Ash will know.
I did my 350/4 springs 20 years ago and they are not showing any problems between coils.
I wouldn't imagine the originals would be pre-plated due to the winding processes and heat treatment.
Ian
Offline Matt_Harrington
Re: Plating springs
« Reply #4 on: November 19, 2023, 01:47:28 PM »
Same here Ian, never had an issue re-plating springs when closed.
Offline DomP
Re: Plating springs
« Reply #5 on: November 19, 2023, 02:39:07 PM »
That's good to hear then, I did just pop some off cuts of copper wire between each coil to open them up and guarantee good coverage.  Seems to have worked well.
1975 XS650B
