Author Topic: Can't fit rear brake in drum after fitting news brake shoes  (Read 1281 times)
Offline Seabeowner
Re: Can't fit rear brake in drum after fitting news brake shoes
« Reply #15 on: November 22, 2023, 06:54:16 PM »
Rear drum is 180mm dia. on 550.  390 is 550F part no. With the shoes centralised on the backplate, what is the diameter?
1973  CB500K1  Candy Ruby Red
1975  CB550F1   Shiny Orange
1978  CB550K     Excel Black
Offline alexdecker
« Reply #16 on: November 22, 2023, 08:46:59 PM »
I only took this before I assembled the wheel with the old brake shoes for now. Can you guys make anything of this image?
« Reply #17 on: November 22, 2023, 08:53:12 PM »
That looks to have been relined but you're also trying to fit 750 shoes which won't fit your hub anyway Alex.
Edit... Have you got a photo of the brake plate.
« Last Edit: November 22, 2023, 08:55:56 PM by Nurse Julie »
« Reply #18 on: November 22, 2023, 09:04:48 PM »
Put your ruler across the drum does it look like an I/d of about 18 cms?
If the answer is yes then it's the wrong shoes.
« Last Edit: November 23, 2023, 08:57:40 AM by McCabe-Thiele (Ted) »
Offline alexdecker
« Reply #19 on: November 22, 2023, 09:31:45 PM »
I only have this photo of the shoes mounted. The packaging per earlier said specifically they should fit a 550F. So either Vesrah wrongly packaged 750 shoes in a 550 packaging or something else is amiss. But the shoes really are quite a bit longer than the other ones.
« Reply #20 on: November 22, 2023, 10:15:05 PM »
The shoes look ok mounted Alex, IF they were 750 ones they wouldn't fit. Everything is looking to be correct yet they won't fit. Try measuring the shoes mounted on the plate as per the pic and see what they measure out at their widest point. I do remember many years ago of members saying they had shoes which didn't fit as they just had to much friction material on them compared to the OE shoes. I think the cure was to sand them down until they fitted. I've bought SBS shoes but as yet I haven't test fitted them, must check them to see if they have the same problem.
« Last Edit: November 23, 2023, 03:38:11 PM by Oddjob »
« Reply #21 on: November 23, 2023, 09:47:33 AM »
It's not an exact science but measuring the width with the shoes when  in place it's 17.8-17.9 cms measuring from the centre section of the shoes.
« Reply #22 on: November 23, 2023, 10:35:50 AM »
Take the shoes off the brake plate, then put each one inside the drum to see if there's difference in radius at any particular point around them.
Shoes are often shamferred at their ends to fit then in to the drum, if they touch just at the ends then you can file that ramp onto them easily to get them touching along their full length.
In other words, you may not need to file the whole brake material, just a "ramp" on the end location of the friction material.
« Reply #23 on: November 23, 2023, 11:09:10 AM »
Is there a big lip on your drum liner by any chance?
« Last Edit: November 23, 2023, 11:18:38 AM by McCabe-Thiele (Ted) »
« Reply #24 on: November 23, 2023, 11:20:13 AM »
Good point K2-K6
Offline peterengland
« Reply #25 on: November 23, 2023, 11:47:25 AM »
I had the same problem with my 550 rear shoes, filed a bit off the ends and sanded shoes a bit and inside rear hub to get them to fit and no problems since.
Suzuki 50
Suzuki GT185
Honda CD175
Yamaha RD350
Honda 50 crunch box
Honda 400/4
Honda 550/4
Honda 750C
« Reply #26 on: November 23, 2023, 12:06:15 PM »
I agree with all the comments about the friction material.  If that is not the problem it could be that the new brake cam is too wide and is holding the brake shoes too far apart.
