Author Topic: Clutch plates  (Read 1462 times)
Offline mo goldie
Clutch plates
« on: December 17, 2023, 12:22:16 AM »
Hi Guy`s
where is the best place to get a set of the 7 Friction clutch plates for the 67`Ko Bomber and springs ?
Been looking on the net searching but come up with D/S he has two original's left and 20 + of the patten ones....... are the patten one`s any good.
Oh could not find the spring tho ?  and still looking for the rear Light len`s he has them but patten ones...if they are any good ?  ;D
cheers
Mo
« Last Edit: December 17, 2023, 12:26:13 AM by mo goldie »
Currant BIKES:
1980 Triumph Bonneville 750 T140/D Special Black & Gold
1962 BSA 650 Rocket Gold Star ( silver )
1977 Norton Commando 850 MK3  Interstate ( silver )
1977 Kawasaki KH400 Triple ( Green )
1999 Harley Davidson 1200S sportster Sport ( silver )
1975 Honda Monkey st70 Dax ( Blue )
1967 Honda CB450 KO Black Bomber
Re: Clutch plates
« Reply #1 on: December 17, 2023, 01:44:51 PM »
I always go for EBC clutch plates Mo .. Think these are suitable but CHECK with them first if you consider buying EBC.
https://ebcbikes.com/products/ebc-motorcycle-clutch-kit-set-ck1130
The original Stanley marked rear lamp is hard to find but fitted to a few models like late CB92, CB72/77, S90 etc so a few around if you search hard enough. Probably nothing wrong with the pattern ones other than the lack of the Stranley markings.
« Last Edit: December 17, 2023, 01:48:07 PM by AshimotoK0 »
Offline mo goldie
Re: Clutch plates
« Reply #2 on: December 17, 2023, 11:31:01 PM »
are ok thanks Ash
I will try them in the morning see what they say ...don`t know if they do springs too but will ask.
Currant BIKES:
Offline mo goldie
Re: Clutch plates
« Reply #3 on: December 18, 2023, 07:27:58 PM »
Hi, Ash
had been waiting all day for the EBC link you gave me to get back and they did to say they do not do them for the Black bomber and they are Not EBC they said they just sele the kits but as I say Not for the Black Bomber tho >:(
so I went to Wemoto and they do the kit and the springs By EBC ...who would have thought that ha LOL.
so hope that will be ok as I have Not had a conformation Email yet............ But it did say for the `67 Black Bomer.
oh just looked again and got this :(
Non Stock Item Ordered On Request Only well looks like this might be a dud too ha :(
Oh are the TRK clutch plates any good as they have them ?
« Last Edit: December 18, 2023, 10:44:24 PM by mo goldie »
Currant BIKES:
Online Bryanj
Re: Clutch plates
« Reply #4 on: December 18, 2023, 11:18:50 PM »
If you down load the 500K1 parts book from Ash stash there is a handwritten notation on the clutch page about using 450 plates for some reasn, which means you could use 500 ones.
Cant remember what it says but i know its there cos it was me that scanned it
Re: Clutch plates
« Reply #5 on: December 18, 2023, 11:32:36 PM »
Pretty sure it was CB77 clutch plates Bryan
Re: Clutch plates
« Reply #6 on: December 18, 2023, 11:35:54 PM »
Bryan... 450 plates CB77 springs
Online Bryanj
Re: Clutch plates
« Reply #7 on: December 19, 2023, 12:23:01 AM »
See the guiness aint killed all the brain cells========yet
Offline mo goldie
Re: Clutch plates
« Reply #8 on: December 19, 2023, 01:04:59 AM »
Hi Bryan
Are you saying part No 22201-268-010 plates will fit the 450 or is it the springs from the 500 will fit ? have you seen what D/S wants for one plate :( £19.31 each ............... hang on just getting up off the floor  ;D
or is it the CB77 305 plates will fit............got a bit confused.com ?
I Need that laydown now  ;D
are I got that Ash
still 450 plates and the 305 springs
still need a laydown ha.
Currant BIKES:
Online Bryanj
Re: Clutch plates
« Reply #9 on: December 19, 2023, 02:31:59 AM »
In all honesty i would fit the ebc plates
1 you probably wont be able to tell the different
2 How many miles are you going to actualy ride it per year
3 When you do ride are you ar all likely to ride it like a hooligan.
AND if a 500 set is cheaper i would use those as the 500 has more bhp
Offline mo goldie
Re: Clutch plates
« Reply #10 on: December 19, 2023, 04:37:51 PM »
Oh managed to get a Genuine lens from a CB77 well hope its all ok as It looks good according to the pictures
so hope it is  ;D
You still did Not say Bryan will the 500 plates fit ?
Currant BIKES:
Online Bryanj
Re: Clutch plates
« Reply #11 on: December 19, 2023, 08:21:26 PM »
They must do if the 450 fit the 500, i have never worked on a 450
Offline mo goldie
Re: Clutch plates
« Reply #12 on: December 20, 2023, 07:13:15 PM »
Hi Bryan
Well I did Not know that either way 450 to 500 and vice versa, so why did EBC say they don`t do them for the 450 B/B
unless they don`t do them for the 500 too now.
so just hope they have or can get them from the Wemoto site....... as if they can`t get them I will get the patterned ones from D/S  if i have too >:(
so watch the space as they say.
Currant BIKES:
Online Bryanj
Re: Clutch plates
« Reply #13 on: December 20, 2023, 08:48:24 PM »
They must physicaly fit or the anotation would not be in the parts book but they may have a different design like slantedgrooves or straight, they may even work slightly different but at the end of the day as long as you have a clutch that lets you change gear and pull away does it matter
Offline mo goldie
Re: Clutch plates
« Reply #14 on: December 20, 2023, 11:21:17 PM »
Yes true Bryan
I just want to fit and forget if you Know what I Mean........ do it once.
we will see how the Wemoto comes up with what they can do for me.
well just had a email with this so they must have then in stock then...well I hope there right
We would like to let you know that we have dispatched the following item(s) from your order:
1 x Clutch Spring Set - EBC Heavy Duty
1 x Clutch Friction Plate Set - EBC
« Last Edit: December 21, 2023, 07:14:02 PM by mo goldie »
Currant BIKES:
