Author Topic: Standard set of 550 piston rings, 13011-374-000  (Read 1226 times)
« on: December 19, 2023, 11:32:05 PM »
Ideally I'd love to just borrow a set, need to check what the end gap clearance is on a set of barrels I've just acquired. Ideally I'd like to reuse the original pistons as the gap between the piston and the bore feels really good, however I prefer to test the end gap as a better indicator of how worn the bore actually is. If the bores are not too bad I'll maybe try another set of standard rings or get them rebored .25mm.
Let me know if you have a set or sets lying around, if one set works out I'd be interested in buying the others.
Offline mickwinf
Re: Standard set of 550 piston rings, 13011-374-000
« Reply #1 on: December 21, 2023, 09:45:51 AM »
Ken I might have a part set as i seem to remember breaking a ring, think it was a 550 so will have a look later today.
« Reply #2 on: December 21, 2023, 02:45:54 PM »
Cheers Mick, so long as one of the top rings is ok that should be fine.
Offline mickwinf
« Reply #3 on: December 21, 2023, 11:31:24 PM »
Completely forgot will look tomorrow
Offline mickwinf
« Reply #4 on: December 24, 2023, 12:46:32 PM »
Just found them ken, sorry but they are 500 rings not 550.
« Reply #5 on: December 24, 2023, 05:10:57 PM »
Thanks for looking anyway Mick. I’ll buy a set from DS I think or wait and see if any turn up on ebay
