Author Topic: CB550F side cover rubber grommets  (Read 949 times)
Offline Plammiman
« on: December 21, 2023, 01:39:24 PM »
I purchased some replacement after market rubber grommets for the side covers on EBay. These are after market cheap version. The fit is poor and virtually impossible to press the covers through the grommets even with grease. Does anyone have any recommendations on purchasing ones that fit correctly.
Re: CB550F side cover rubber grommets
« Reply #1 on: December 21, 2023, 01:47:02 PM »
I had the same problem on the K3 ended up fitting the old ones back in. Not sure about DS but CMS has the nos ones.
« Last Edit: December 21, 2023, 01:52:03 PM by Johnny4428 »
1978 Honda CB550K3.
« Reply #2 on: December 21, 2023, 02:11:10 PM »
The K3 IIRC uses 2 different grommets, 2 of the same at the top and a slightly different one on the bottom lug, this is because the bottom lug is smaller and rounder than the upper lugs.
Which of these is the problem? I ordered a big bag of genuine ones off USA Ebay some while ago thinking they were the top ones and I think they were the bottom ones and of course my 500 doesn't use that type.
« Reply #3 on: December 21, 2023, 02:27:09 PM »
I think Julie has some
« Reply #4 on: December 21, 2023, 02:39:05 PM »
But are they genuine or copies is the question. A lot of copies look ok but don't work when fitted, I would say if it's not in a sealed genuine Honda bag you're taking a risk of it either not fitting or falling apart are a short while with the possibility the panel gets lost when they do. I'm looking at seeing if I can drill the top lugs on the panel so I can fit an R clip through the hole so it can't fall off in transit or anyone can remove it without lifting the seat. Not tested the theory yet but it sounds doable.
Offline peterengland
« Reply #5 on: December 21, 2023, 04:59:36 PM »
I had some like that but just carefully shaved off a bit inside the grommet and they fitted perfectly
Suzuki 50
Suzuki GT185
Honda CD175
Yamaha RD350
Honda 50 crunch box
Honda 400/4
Honda 550/4
Honda 750C
Offline Seabeowner
« Reply #6 on: December 21, 2023, 07:35:18 PM »
The grommets are the same AFAIK on all the 500/550s. 17247303000 and  83551300000. Except one of the large ones is turned through 90deg on the Fs and K3.
I had some cheap ones and used a soldering iron to melt a chamfer on them and trimmed them up. But on my best bikes I bought genuine.
1973  CB500K1  Candy Ruby Red
1975  CB550F1   Shiny Orange
1978  CB550K     Excel Black
« Reply #7 on: December 21, 2023, 09:02:30 PM »
The problem with the ones I had was they appeared to be a lot harder than the originals.
1978 Honda CB550K3.
Offline DomP
« Reply #8 on: December 21, 2023, 09:31:43 PM »
Interesting read as I need to replace mine that fell apart as soon is I got near them.
  I wonder if anyone with an F model could do me a favour and measure the spacings of the gromet tabs, or trace them? I'm uncertain whether I have a warped right side cover or if the tabs have been removed and welded back on in the wrong place (unlikely as there are no signs anywhere on the bike that it's been messed with.
1975 XS650B
1976 CB550F1 current project
2012 Triumph Daytona 675
« Reply #9 on: December 21, 2023, 09:35:35 PM »
Always worth warming them first
Soak in hot water
Make them malleable
« Reply #10 on: December 21, 2023, 10:30:59 PM »
Never thought of that John but just was just wanting reassurance that I could remove the panels without breaking them once fitted.
1978 Honda CB550K3.
« Reply #11 on: December 22, 2023, 02:01:18 AM »
TBH I thought the 500 used all the same type, they look the same TBH except I think the bottom one is slightly smaller, that's good news, means at least I'll get to use 2 of my new ones now.
« Reply #12 on: December 22, 2023, 02:24:25 AM »
I think they are even same as 750 Ken
Offline Skoti
« Reply #13 on: December 22, 2023, 07:33:48 AM »
Panels on my F1 were a bit slack, some shrink wrap on the lugs cured that.
Skoti
1976 Honda CB750F1
« Reply #14 on: December 22, 2023, 08:28:15 AM »
Nice one Skoti! Good tip.
1978 Honda CB550K3.
