Author Topic: Threading switch gear cable through handlebars  (Read 1330 times)
Offline davidcumbria
« on: January 02, 2024, 08:06:23 AM »
Hi posting this here rather than in my cb550k1 thread as applies to several models. I have to remove and replace my right switchgear so unplug everything and bars off. Getting the old cable out and new one in seems tricky. Would be grateful to hear of tips and tricks for doing this. String or wire and best type as a pull through lead ? Best method/ place to secure it ? Silicon spray as best lubricant ? Any other tips ?
500/4 in 79. No bikes for 30 years. 750/4 in 2013, 550/4 in 2023. Also own  R1100GS, RD350LC YPVS , Triumph Street Triple, Yamaha XT250
Offline Multiman
Re: Threading switch gear cable through handlebars
« Reply #1 on: January 02, 2024, 08:30:57 AM »
I used heavy duty strimmer line taped to the wires. No lubricant just make the join as smooth as possible. Easier than it appears at least it was on my 400/4
« Reply #2 on: January 02, 2024, 08:31:43 AM »
Bicycle gear cable (very thin Bowden with small barrel nipple) secured within the loom plug area with electrician tape will lead it through.
Silicone spray, agree with that to help it.
« Reply #3 on: January 02, 2024, 11:35:04 AM »
Talcum powder
Online Oddjob
« Reply #4 on: January 02, 2024, 03:51:24 PM »
I use the copper core of some 2.5mm T&E cable, just strip off the insulation or use the earth part of the wire. A little hook in the end and you can slide it inside the back of one of the bullet connectors. I tape up the rest of the bullets etc to reduce them twisting around and jamming inside the bars. Some silicon oil doesn't hurt to get them all to slide easier as well. If it jams don't tug, just pull it back and try again. As you're fitting a new switch the wiring cover will be pristine but most are split etc and they have a tendency to grab, which always makes me wonder what are they grabbing onto, it's inside a tube for gods sake. If the covering is split either replace with new or tape up.
Offline cbxman
« Reply #5 on: January 02, 2024, 06:07:29 PM »
My two pence worth.
I use a hair dryer to warm the handlebar and the PVC becomes softer and manageable, particularly in this weather!  The wires just pushes through quite easily even old brittle stuff.  Not too much though!!!!
CB750 K1 1971 Wisconsin, USA
Suzuki GT550 J 1972 Michigan USA
CB360 G5 1975 UK
CBX1000 A 1980 (European Direct Sales)
CB1300 A5, 2005 UK
Offline ozzybud
« Reply #6 on: January 03, 2024, 01:53:02 AM »
I use an old internal cable from a used throttle cable. Use electrical tape to secure the cable to the wire loom with the lead nub just behind the last plug. Then tape the entire joint smooth with the tape. Put a little dish soap on the joint. This has worked every time for me with minimal tugging.Work both ends by pulling on the cable and pushing on the wire Bundle
1976 Z50 YELLOW
1970 CT70 BLUE
1971 CT70H ORANGE
1972 CT70H GREEN
1973 CL200 BLUE
1975 CB360T RED
1975 CB400F BLUE
1975 CB550 ORANGE
1976 CB750F RED
« Reply #7 on: January 03, 2024, 09:00:23 AM »
Many thanks  for all the replies. Reckon this thread should be moved to the tips and tricks section.
Offline Lobo
  • Lobo
  • Lobo
    • Lobo
« Reply #8 on: January 04, 2024, 12:35:37 PM »
…bind the head of the loom with PTFE plumbing tape - far easier to deal with than electrical insulation tape. Pull string of your choice.
Offline magpie114
    • A.M. Photoblog
« Reply #9 on: January 04, 2024, 01:38:43 PM »
A short length of heat shrink over the connectors and and pull string has worked for me
Honda CB350F
Honda VFR400
Suzuki 650
