Author Topic: Rear indicator earth.  (Read 522 times)
« on: January 05, 2024, 06:05:17 PM »
I had one of these fail today surprisingly. After discovering there was no offside rear indicator today I checked the obvious, the bulb which appeared to be fine gave it a wiggle as you do, nothing! Checked connections under seat then with multimeter checked for power at bulb socket which showed power supply ok. Soon became apparent that there was no earth to light. The culprit was the earth/bracket mount (thingy). A few taps with the hammer on the rivet and it now shows good connection. I will remove rivet at some point to clean connection before riveting again.
1978 Honda CB550K3.
Offline davidcumbria
Re: Rear indicator earth.
« Reply #1 on: January 05, 2024, 07:54:37 PM »
Glad you problem solved it. My rear indicators only have this contraption on one side. The other side works fine and I reckon is earthing through the grabrail it’s bolted to.
500/4 in 79. No bikes for 30 years. 750/4 in 2013, 550/4 in 2023. Also own  R1100GS, RD350LC YPVS , Triumph Street Triple, Yamaha XT250
« Reply #2 on: January 05, 2024, 08:33:54 PM »
I just attached an earth cable inside the lamp unit threaded it down the stalk & to an earth under the seat.
« Reply #3 on: January 05, 2024, 09:46:13 PM »
OR drill the rivet out and use a self tapper.
Be advised there are two differentbracket for different grab rails
