Author Topic: Saturday salvage.  (Read 1837 times)
Re: Saturday salvage.
« Reply #15 on: January 17, 2024, 06:51:16 PM »
https://youtu.be/4HQFqyvMTos?si=EVfXK0W_BqqBovg6
No Julie, it’s under house so internal stairs! Well she’s a runner Julie you were right, it’s a Honda ofcourse it’s going to run. Managed to video if link works.
1978 Honda CB550K3.
« Reply #16 on: January 17, 2024, 07:00:44 PM »
Don't tell me that's the bike in the first post pics?
« Last Edit: January 17, 2024, 07:39:39 PM by McCabe-Thiele (Ted) »
« Reply #17 on: January 17, 2024, 07:09:38 PM »
Wayhay, well done Johnny, the engine sounds OK and that a lovely noise from that megaphone. Fantastic.
« Reply #18 on: January 17, 2024, 07:40:57 PM »
What a lovely noise that makes, makes me want to refit my Dunstall.
Offline magpie114
    • A.M. Photoblog
« Reply #19 on: January 17, 2024, 08:20:04 PM »
What a result, sounds great.
Honda CB350F
Honda VFR400
Suzuki 650
« Reply #20 on: January 17, 2024, 10:16:12 PM »
Same bike Ted!
1978 Honda CB550K3.
« Reply #21 on: January 17, 2024, 11:15:37 PM »
That sounds great Johnny, the video makes it look and sound like a pit garage prior to the start of a 24hr endurance race👍
1976 Honda 400/4
1978 Honda CB400/4 'Rat' bike
Offline Rozabikes Tim
« Reply #22 on: January 17, 2024, 11:22:47 PM »
What prep to get it running? Usual carb clean and points set up?
« Reply #23 on: January 18, 2024, 12:51:09 AM »
Well done Johnny, that sounds ace!
« Reply #24 on: January 18, 2024, 06:30:03 AM »
What were you tinkering with near the offside side panel, at first I thought it was the fuel feed but that looks to be hanging off the rafter.
« Reply #25 on: January 18, 2024, 07:47:10 AM »
Ken there’s a choke lever with a sticky cable fixed to side of frame! The wiring is home grown so leaves a lot to be desired. No kill switch, so thought I would disconnect the wire I connected to get power from battery to coils but the bike just kept running so must be being fed from alternator as well. Tim I just pulled the carbs removed all jets cleaned and put them back on. Just cleaned points had to reconnect one plug lead that had detached from plug cap.
« Last Edit: January 18, 2024, 07:49:48 AM by Johnny4428 »
1978 Honda CB550K3.
Online Bryanj
« Reply #26 on: January 18, 2024, 09:26:21 AM »
Yes it will run from alternator after starting as long as revs are high enough to provide the excitation power
« Reply #27 on: January 18, 2024, 09:55:50 AM »
Blimey Johnny, the engine whisperer. It's handy it's running as now it will be easy to get up the plank to the skip. ;D ;D
« Reply #28 on: January 18, 2024, 10:22:01 AM »
Good work, sounds quite good condition from it's running noises too. No real smoking, just condensate , and with balance, compression etc sounding absolutely normal.
« Reply #29 on: January 18, 2024, 10:42:50 AM »
😂😂😂 I like it!
1978 Honda CB550K3.
