Author Topic: Brake Caliper Black or Polished  (Read 810 times)
Offline Eldrick
« on: January 30, 2024, 05:17:19 PM »
Should my brake caliper be painted black or left shiney...?
I see in the worksop manual it is black then I see on 'car and classic' some are painted or even just the inside caliper is black.  This being a UK 1975 model if that makes a difference.
1975 Honda CB400f - Red
Re: Brake Caliper Black or Polished
« Reply #1 on: January 30, 2024, 05:40:24 PM »
Black
Offline Eldrick
« Reply #2 on: January 30, 2024, 05:56:30 PM »
thank you
 :D
Offline TrickyMicky
« Reply #3 on: January 31, 2024, 12:32:37 PM »
If you use a good brand of aerosol Satin Black it gives a half decent finish.
Online McCabe-Thiele (Ted)
« Reply #4 on: January 31, 2024, 12:41:20 PM »
Probably not necessary but I bought the black caliper aerosol paint as it's heat resistant
« Last Edit: January 31, 2024, 11:57:09 PM by McCabe-Thiele (Ted) »
« Reply #5 on: January 31, 2024, 11:31:37 PM »
Probaly not necessary but I bought the black caliper aerosol paint as it's heat resistant
I second that Ted👍. I think I baked mine after painting to achieve the heat resistance. It dried a satin black colour. Finish was great and never chipped.
1976 Honda 400/4
1978 Honda CB400/4 'Rat' bike
Online Oddjob
« Reply #6 on: February 01, 2024, 06:52:09 AM »
Or get it ceramic coated, resistant to heat and brake fluid. Not expensive either, possibly as cheap as buying a tin of aerosol and no stinking up the kitchen curing it.
Offline davidcumbria
« Reply #7 on: February 01, 2024, 06:59:00 AM »
Had mind powder coated. Tough, shiny and resistant to brake fluid.
500/4 in 79. No bikes for 30 years. 750/4 in 2013, 550/4 in 2023. Also own  R1100GS, RD350LC YPVS , Triumph Street Triple, Yamaha XT250
Online Oddjob
« Reply #8 on: February 01, 2024, 08:36:12 AM »
The problem with powder coat is how thick it is, on some parts this is a bonus, on others it's a drawback. I've had powder coated calipers and they do last, given a choice in that location I'd go with ceramic, matches the original paintwork better, which TBH wasn't so much paint as an alloy stain. Like how the handlebar switchgear is done and the splitter under the headlight.
Frames, definitely powder.
Offline Matt_Harrington
« Reply #9 on: February 12, 2024, 08:45:08 AM »
I've recently restored a few Brembo calipers for one of my other bikes. I was recommended some corrosion resistant epoxy primer (to quote the guy "...stick like etc etc.." after which some decent satin black was applied. Seems to be working well at the moment. The caliper on the 400 i'm working on was cerakoted. The advantage is that the paint has longevity.....(I hope!)
