Author Topic: Painting underside of rear fender  (Read 523 times)
Offline Athame57
    • SeaWitch Artist
« on: February 16, 2024, 08:29:06 PM »
My rear fender has a lot of blemishes appearing under it now, so sometime soon I'll be taking it out for a good sprucing up. Is it a bad idea to paint beneath it, how should I best go about the job? :)
« Last Edit: February 17, 2024, 12:07:13 AM by Athame57 »
1978 CB400F2 called Elen.
Offline ozzybud
Re: Painting underside of rear
« Reply #1 on: February 16, 2024, 09:47:41 PM »
It was the standard Honda flash Chrome from the factory which is very thin. I would suggest scrubbing with Scotcbrite or steel wool. Then use Por-15 or a similar rust neutralizer. Then rattle  can some silver metallic paint over that. It will be easy to keep clean and look attractive.
1976 Z50 YELLOW
1970 CT70 BLUE
1971 CT70H ORANGE
1972 CT70H GREEN
1973 CL200 BLUE
1975 CB360T RED
1975 CB400F BLUE
1975 CB550 ORANGE
1976 CB750F RED
Offline Bradders
« Reply #2 on: February 16, 2024, 11:33:33 PM »
I have just done the underside of both of my mudguards, I derusted as much as possible with I think it was Kurust and painted with silver Hammerite. I’m pleased with the look but I guess only time will tell how it lasts. I never use my bike if the roads are wet or salty though.
Offline davidcumbria
Re: Painting underside of rear fender
« Reply #3 on: February 17, 2024, 06:38:43 AM »
After rust treating and paint spraying I think a protective coating of xcp rust prevention spray should keep it good. It is much more robust than acf50 ( does way better on tests ) and forms a hard protective skin.
500/4 in 79. No bikes for 30 years. 750/4 in 2013, 550/4 in 2023. Also own  R1100GS, RD350LC YPVS , Triumph Street Triple, Yamaha XT250
Offline DomP
« Reply #4 on: February 17, 2024, 08:36:21 AM »
Another option after treating the rust with something like deox gel is bilt hamber dynax ub, it's a dark brown/black coloured self healing underbody wax.
1975 XS650B
1976 CB550F1 current project
2012 Triumph Daytona 675
« Reply #5 on: February 17, 2024, 10:50:43 AM »
This is an interesting thread. I'm collecting my chrome from Ashford Plating on Monday and will paint the underside of the front and rear mudguards, the chainguard (although flung off chain lube will help keep that rust free) and the underside of the points cover to stop the potential arcing from the points.
I remember froma previous thread posted by Ken (Oddjob) a while ago where he mentioned about rust forming in the rolled edges in the mudguards.
1976 Honda 400/4
1978 Honda CB400/4 'Rat' bike
« Reply #6 on: February 17, 2024, 12:03:06 PM »
On my 500 I used the Zinc Galvanising paint followed by a silver engine paint when base coat completely dry.
