Author Topic: Candy Garnet Brown  (Read 523 times)
Offline Seabeowner
Candy Garnet Brown
« on: February 26, 2024, 05:07:19 PM »
Looking for criticism and sources for paint.
I have an old tank that I have de-rusted and filled a few small dents. It is not really worth spending money on a professional finish as it will be another spare. I have sprayed a few bikes, but that was 40 years ago! And fifty years ago I bought a new 500 (my avatar) in candy garnet brown, so that is the colour for this one.
1.   Spray with etch primer because that’s what our factory sprayer did first when I was working. Do I need this?
2.   Spray with epoxy primer. Final light rub down.
3.   Base coat. What do I need?
4.   Spray candy garnet brown all over. How much paint do I need. 500ml seems enough.
5.   Cure.
6.   Mask for black panels at side of tank.
7.   Spray black.
8.   Cure.
9.   Apply striping decals.
10.   Spray 2K lacquer. I know it’s nasty stuff.
Intend to use aerosol rattle cans for steps 1, 2, and 10.
Will also do a test piece as I progress to check paint compatibility.
This has been on here before, but looking for sources and recommendations for paint. I only remember RS paint.
Thanks for any info/advice.
1973  CB500K1  Candy Ruby Red
1975  CB550F1   Shiny Orange
1978  CB550K     Excel Black
Offline mickwinf
Re: Candy Garnet Brown
« Reply #1 on: February 26, 2024, 05:33:41 PM »
Just done the tank for Lazarus in black using spray cans, your method seems ok but I might put at least one layer of lacquer before stripes to even the transition between colours and stripe.
Online AshimotoK0
« Reply #2 on: February 26, 2024, 11:19:19 PM »
I would use German made SprayMax 2k gloss rattle can for the clear coat. Expensive but lovely spray pattern and superb finish if you are careful. I always wear my air fed mask with it. Some people use a Gersen disposable mask with it.
Offline Seabeowner
« Reply #3 on: February 27, 2024, 05:05:10 PM »
Thanks for the info Mick and Ash.
Any other sources for the candy paint?
And what about basecoat. Nothing on RS site. I could give them a ring.
Offline Seabeowner
« Reply #4 on: February 28, 2024, 05:09:07 PM »
Well according to RS paints their garnet brown does not require a base coat.
Other sources say UC-16-100 which seems to be cloud silver.
Am considering this on top of their silver.
https://www.ebay.co.uk/itm/284052756978
