Author Topic: CB400F Throttle cable A & B lengths  (Read 7391 times)
« on: February 27, 2024, 11:19:34 PM »
Does anyone know the CB400F Throttle cable A & B lengths please?
Have some similar cables mixed up (eg CB250/360G5) and I need to identify which are indeed for the 400F
Re: CB400F Throttle cable A & B lengths
« Reply #1 on: February 27, 2024, 11:21:20 PM »
Didnt the honda cables have the middle part number on them Ash
« Reply #2 on: February 28, 2024, 04:39:28 PM »
Only markings are TSK and Made in Japan Bryan. I think one is deffo Genuine but need to work out if for a 400F Anyone else can measure one for me please.
« Reply #3 on: February 28, 2024, 04:46:57 PM »
This is what 4 into one say.
Honda part numbers:
Throttle Cable A - Pull - 17910-377-000
Throttle Cable B - Push - 17920-377-000
Dimensions:
35.25" Total Length - 31.25" Inner Housing - 4" Slack
M10 Throttle side thread in
Throttle side cable stop = 6mm Diameter x 7mm Wide
Carburetor side cable stop = 6mm Diameter x 10.25mm Wide
In line carburetor side cable adjuster
M6 cable adjuster on the carburetor side.
36" Total Length - 32.25" Inner Housing - 3.75" Slack
M12 Throttle side thread in
Fits Honda:
CB400F Super Sport - 1975-1976 (Does not fit 1977 model with stock handlebars)
Offline Aye Gee 1977
« Reply #4 on: February 28, 2024, 05:24:20 PM »
Aren't the throttle and the carburettor at the same end of the cable?
The twistgrip is typically at the other end.
« Reply #5 on: February 28, 2024, 08:13:16 PM »
I ordered both cables from DSS Ash. They are still in their wrapping although I don't know what make they are and obviously I haven't tried them on the bike but I can unwrap them tomorrow, give them a measure and let you know the lengths if this helps?
1976 Honda 400/4
1978 Honda CB400/4 'Rat' bike
« Reply #6 on: February 28, 2024, 09:06:24 PM »
That would be great Dave as DS claims his are made by the OEM supplier to Honda.
« Reply #7 on: February 28, 2024, 09:16:09 PM »
I bought my two 400 cables from DS - they fitted perfectly.
« Reply #8 on: February 28, 2024, 11:10:31 PM »
DS claims TSK are the oem supplier to Honda and the ones i have had have always fitted, i am sure the genuine spare had the modle number on the cable but tsk would not be allowed to do that
« Reply #9 on: February 29, 2024, 08:37:54 PM »
Here you go Ash, these are the measurements from the two new cables I received from DSS last week;
DSS Pattern Cable Numbers;
TSK HI-LEX Control Cable A - Pull – Ref No. 17910-377-000 TSK No. 2PA1179
Japan Quality Washo Co. LTD (made in Japan) Cable B – Push, Part No.17920-377-000
Dimensions;
Throttle Cable A – Pull
35.5” Total Length – 32.25” Inner Housing  - 4” Slack
Throttle side cable = 6mm Diameter x 7mm Wide
Carburettor side cable stop =6mm Diameter x 10mm Wide
In line carburettor side cable adjuster
2 x 6mm cable adjuster nuts on the carburettor side
Throttle Cable B – Push
36” Total Length -  32.75” Inner Housing – 3.5” Slack
Throttle side cable stop  = 6mm x 6.5mm Wide
Carburettor side cable stop = 6mm Diameter x 10mm Wide
M6 cable adjuster nut on the carburettor side with ‘U’ Shaped flanged washer on engine side .
You will notice there are some slight variations between the cable sizes given by 4 into 1 especially the throttle side thread in on the pull cable which on the new cable is not M10 but M12 (maybe this is why the M10 doesnt fit the 1977 models?).
At least the above should give you an idea what you have.
1976 Honda 400/4
« Reply #10 on: February 29, 2024, 11:48:41 PM »
Thanks Dave ... great info.
« Reply #11 on: March 02, 2024, 01:19:20 PM »
Even though I have quite a few NOS looking cables they all seem longer than those dimensions so possibly off a 250G5
I was therefore just about to order the DS ones which he claims are OEM and the only difference between his and Honda is the price.
BUT I can't see a spring on the DS opening one. I always thought that both cables had the spring fitted.
Bit confused as I have seen a NOS in bag genuine one for sale with no spring on the throttle opening cable but Part Book deffo shows one fitted.
« Last Edit: March 02, 2024, 01:39:00 PM by AshimotoK0 »
« Reply #12 on: March 02, 2024, 02:26:15 PM »
I can't see any spring on the parts book pics just a sectional view of the outer cable without the black outer layer ?
I can't recall any springs in my old original cables or the DS replacements I always aasumed the return spring(s) on the throttle system were strong enough.
« Reply #13 on: March 02, 2024, 03:18:23 PM »
Here you go Ted ! Protection springs I guess. I think the DS push 'B' cable has one fitted but not the other 'A' one.
« Last Edit: March 02, 2024, 03:21:53 PM by AshimotoK0 »
« Reply #14 on: March 02, 2024, 05:06:11 PM »
I did not think they were any springs  on the throttle cable itself - I thought that was a sectional representation of the cable - I live and learn Ash assuming you are right - I bow to your experience.
The spring if fitted between the quadrant & the adjuster would serve no real purpose  it would just squash up and serve no purpose - am I missing something here or is it acting as an outer cable buffer?
« Last Edit: March 02, 2024, 05:16:51 PM by McCabe-Thiele (Ted) »
