Author Topic: I haven't any of this in my Garage 0W/20 Sythetic Oil.  (Read 1805 times)
Re: I haven't any of this in my Garage 0W/20 Sythetic Oil.
« Reply #15 on: March 10, 2024, 04:39:41 PM »
Ted, ebay item 303566439357
Sometimes comes up on special offer, way cheaper than local parts suppliers, i use it in the lexus rx mate
Bryan, was not calling you misleading, just the eBay post as it seems to list every oe specification imaginable in the photos, I also drive a Toyota, and a modern API SP, oe ILSAC gf6 is all the Toyota’s require in terms of specification.
They are really "touchy" about specs, certainly.
I was reading of one element recently that claimed (think it was a castor product) good resistance against pre-ignition in direct injection petrol engine ! Then wondered just how much oil would be interning the combustion chamber to have such an effect, also the consumption of oil at such a level.
I know DI can give some problem with bore wear as unintentional characteristic, perhaps with more advanced mileage, but didn't realise it could get that bad  :)
« Reply #16 on: March 10, 2024, 04:55:49 PM »
Due to my age I struggle getting out of low vehicles hence a small sit up & beg style.
« Reply #17 on: March 10, 2024, 05:23:01 PM »
It's not that long ago that only Nissan ATF suits a Nissan Automatic, Merc have to use only Merc ATF.
All a myth these days this endless list of manufacturers only ATFs.
« Reply #18 on: March 10, 2024, 05:38:43 PM »
I do know that some  Merc Diesels that have a unique laser cut angled injector nozzle insisted on a particular low ash oil was used to minimise deposits accumulating from combustion products - this was over 10 years ago.
« Reply #19 on: March 10, 2024, 11:20:46 PM »
Pretty sure that Volvo has a specification for the 0w20 to meet for that car beyond just 0w20.
Volvo VCC RBS0-2AE 0W-20 synthetic oil Isn’t the same as a regular 0w20 for typical Asian cars or dexos1gen2 oils
That eBay listing is misleading as the TDS sheet doesn’t include the Volvo approval. https://www.mannol.de/create-pdf/108/en
Probably all the same inside the containers - Castrol Edge list several versions of their 0W-20 oil, Professional, variants for Jaguar & others, LLiV it's a minefield of options too long to list.
As it will be for top up only if needed I will visit my local Volvo Dealer to obtain the one in the handbook VCC RB50-2AE 0W-20 Castrol Edge Professional as you have confirmed CB750r. When I check similar Edge variants they come up as unsuitable for my model. They also make a non professional version of the 0W-20 Edge.  I think they will want around £18.00 for a litre - daylight robbery but until the warranty runs out I'll stick with the main dealer - luckily there are a couple of local garages that  specialise in Volvo Servicing outside of the dealer network. Even Opie oils do not show any oil suitable for my VRM.
No dipstick fitted just a dashboard display checker when the engine is running.
Online AshimotoK0
« Reply #20 on: March 10, 2024, 11:46:54 PM »
Staying loyal to our beloved brand on here ...  I bought a new Jazz Hybrid last year and evidently it uses synthetic 0W-20 oil.
Pretty amazing MPG around town.
Offline Cb750r
« Reply #21 on: March 11, 2024, 12:14:27 AM »
Ted that graph I sent you is from of one of the worlds largest oil additive packages manufacture. That graph shows differences to the specifications, and therefore the differences in the properties of the different oils.
You can get Volvo approved oils from a few sources. I sell Motul automotive oils in Canada and they have a factory approved product as attached. I’m sure as it’s a French company you can get it.
I’m sure there are several other options.
« Reply #22 on: March 11, 2024, 01:35:08 AM »
Ted, i think you are right in using the Volvo oil till its out of warrantee.
As you have seen its dearer to buy 1 service quantity than the 20ltr from mannol, who are a large german supplier, you could look on their website for exact correct spec then see if you can get it elswhere
« Reply #23 on: March 11, 2024, 09:24:02 AM »
Why would you need to top up the oil on a new car Ted?
My wife’s Audi is 8 years old and I’ve never touched it.
2022 Tiger Sport 660
Offline Rozabikes Tim
« Reply #24 on: March 11, 2024, 09:41:34 AM »
Interesting....
I have a brand new Ford Tourneo. Made by VW and the same as Caddy. Flashed up needing oil at 4k miles. Likewise my friends brand new Audi Q3 did similar. Apparently VWs can do this but then settle down.....?? Spoken to Ford on mine and told to pop it in  to have it looked at. All feels a bit uncomfortable to me as likewise I thought new vehicles now us little oil. My Expert can that ive had from new does not use much...
« Reply #25 on: March 11, 2024, 09:47:12 AM »
Could be they have been "run in" to gently,
And the rings haven't sealed
« Reply #26 on: March 11, 2024, 11:00:16 AM »
Interesting thing about modern engines using little or no oil is often a bit of a myth in my experience  especially for short journey work vehicles  - this is anecdotal  personal experience on my older vehicles (5-20 yrs old).
Modern synthetic oils become contaminated with sulphur based oxides that are acidic,  the manufacturers add micronised chalk to neutralise the effect of the sulphur in addition other combustion products become absorbed into the oil over time replacing the actual oil used. This is worse in low mileage vehicles that often do not run at optimum temperature for many miles so also have some sump dilution from running on choke or cold start enrichment.
The dip stick level shows little or no change due to this deterioration in the oil quality as good oil is replaced by other compounds. It is when you suddenly go on a long trip say for your holidays that the oil gets hot and a lot of the water & petrol oil contaminates are effectively boiled out leading to a sudden drop in the dipstick level. Both myself & my brother have noticed this phenomena. I drove my car  about 160 miles having checked my oil before departure (oil had been in place for about 5k miles) on arrival my oil had gone from full on the dipstick to the low mark. I was quite concerned - I put a litre of oil in then checked it when we returned home - it was still full.
It seems odd that an engine would use oil for a 160 mile journey then not use any on the same retrurn distance - the above is how I have interpreted the outcome. This has been my experience with several brands of used cars over the last 20 years. Going back to the 1960-1990 it was quite different as some  oil consumption was the norm.
« Reply #27 on: March 11, 2024, 11:39:14 AM »
You're probably right Ted.
The Q2 sits outside for three weeks at a time and gets used about once per month for visiting the mother-in-law (300 miles round trip)
Quite uncommon usage profile I'd imagine as we live in the town centre and walk everywhere.
5000 miles per year. 1 service per year.
I do ask myself why we own a car sometimes.
« Reply #28 on: March 11, 2024, 11:49:15 AM »
Interesting....
Keep an eye on it and record of just what it does, it'll either get better or go to warranty  :(
Generally within VAG engines there's been some historic record of oil consumption, often associated with indifferent looking after, or dubious claim at least.
Theres shift in running in however from what we would call "classic"  characteristic, with many manufacturers using piston rings pre honed prior to fit as std in supply chain, with variation in metallurgy caused by adaption to low zinc type oils.
Couple this, with parsimonious fuelling and accuracy of delivering that fuel, then traditional wetting of cylinder bore from excess, consequential lubrication failure in facilitating local in engine hone condition for bore and rings, has a different look to it. Hence giving it time to "settle" is a valid route in assessing what it's going to do.
Completed well they seem to go on to complete mileage without problem. A friend with Audi A4 just sold it last year with 275,000 miles on it. A 1.9 Tdi with nothing other than cam belt and oil changes completed (we exchange tech support to help each other out ) and replacement of overrun clutch pulley on alternator.
We've an old Touran 04 plate with us from new (first as an employee company car, then bought at end of term) with 27,000 mls first oil service, 21,000 second , but now I routinely run it at 9,000 interval for oil, filter etc. Now passed 140,000 mls, doesn't use oil in between changes.
Just taken on recently a 135,000 + mls (another tech support family arrangement  :) )  a V8 40V within spitting distance of 400 bhp, run on Castrol 0W 30 for it's life, smooth and quiet, hasn't yet used anything measurable, oil stays clean too and with, ahem  ;D entertaining performance.
« Last Edit: March 11, 2024, 12:00:32 PM by K2-K6 »
« Reply #29 on: March 11, 2024, 12:17:11 PM »
Cheers for the normal superb technical observations.
Yes keeping an eye on things.
I had read somewhere too about lean burn engines not helping.
