Author Topic: Neutral switch disassembly  (Read 1514 times)
Offline Jan B
  • Everything you can leave behind is a gain
« on: March 09, 2024, 03:42:21 PM »
Does anyone have experience with disassembling a neutral switch? I would like to zinc plate the steel parts. The non-conducting middle part seems to be locked in place with some kind of laquer.
CB500K1
CB750K2 [project]
BMW F800GS
Offline Jan B
Re: Neutral switch disassembly
« Reply #1 on: March 10, 2024, 12:01:27 PM »
I decided to give it a try myself. I applied some heat from a heatgun untill the "laquer"started to bubble. With special tool I made with a 3D-printer I was able to unscrew the non-conducting part.
Below all the parts:
After plating:
Happy with the result. Now i have to do some research as to find a suitable locking agent. Maybe a medium treadlocker...
« Last Edit: March 10, 2024, 04:34:27 PM by Jan B »
CB500K1
CB750K2 [project]
BMW F800GS
« Reply #2 on: March 10, 2024, 12:18:53 PM »
That's a lot of attention to detail for such a small part.
It will be interesting to see the parts you are plating when they are done.
« Reply #3 on: March 10, 2024, 01:23:18 PM »
Nice one
« Reply #4 on: March 10, 2024, 02:32:11 PM »
Great work Jan ... that should be in 'Anoraks Corner' so it can be easily found and referenced in the future.
If it was a good working unit, I would be inclined to seal up the ball end in some way, then bead blast clean and zinc plate at home. I don't think a commercial plater would entertain plating it that way though. So you would have to do as you have done and break down to the component parts.
« Last Edit: March 10, 2024, 02:57:33 PM by AshimotoK0 »
Offline Jan B
« Reply #5 on: March 10, 2024, 04:26:20 PM »
The non-conducting part is quite brittle, so blasting is a bit risky.
Assembly with medium Locktite went very well. Quite pleased with the result.
@Steve, can you move the thread to Anorak's corner?
CB500K1
CB750K2 [project]
BMW F800GS
« Reply #6 on: March 10, 2024, 06:36:14 PM »
I would cover the non-conducting part with something like Blu-tac or Plasticine and then bead blast . Agree ... better to dismantle though Jan.
