Author Topic: Regulator Rectifier  (Read 5866 times)
Offline Pauarc
Regulator Rectifier
« on: March 22, 2024, 12:34:19 PM »
Regulator Rectifier has anyone changed to all in one like pic my regulator seem to be faulty
Cb750k2
Re: Regulator Rectifier
« Reply #1 on: March 22, 2024, 01:39:11 PM »
Yes,
I fitted a solid state unit,
About 8 years ago
Seems to work perfectly
« Reply #2 on: March 22, 2024, 03:12:43 PM »
I looked at one of those during my 400 build - decided against as there will be some different/ new wiring connection needed. I just tinkered with the regulator to raise the voltage a tad.
Offline Pauarc
« Reply #3 on: March 22, 2024, 03:27:54 PM »
The points are badly pitted what is the best way to clean or can they be changed that’s why I thought it would be better to change to a all in one they say it’s a derect change over
Cb750k2
« Reply #4 on: March 22, 2024, 03:38:11 PM »
I cleaned my contacts up using a nail board to remove the high spots.
Offline Pauarc
« Reply #5 on: March 22, 2024, 03:43:08 PM »
I will try that do you have to reset after that
Cb750k2
Offline flatfour
« Reply #6 on: March 22, 2024, 04:10:31 PM »
I fitted the David Silver combined regulator/rectifier to my CB750 K2 around four years ago. Although I don't have the bike any longer it behaved perfectly in the three years that I ran with it.
Even for someone like me, who finds it hard to change a light bulb without causing another problem, it was simplicity itself to fit.
« Reply #7 on: March 22, 2024, 04:34:39 PM »
After I cleaned my regulator points the voltage output was actually a tad higher so I changed nothing.
Can't remember the actual figures now it was a couple of years ago.
« Reply #8 on: March 22, 2024, 04:57:28 PM »
Just cleaning the "pip" off shouldnt alter much if anything
