Author Topic: 1975 CB500 K1 rear brake pedal arm position  (Read 761 times)
Offline martin_uk
« on: April 05, 2024, 11:17:41 AM »
As it was already in bits, I didnt get to see how fitted.
In the Haynes manual says to put arm in front of swinging arm and also shows return spring on inside of frame.
It does not work like this and lever binds up with actuator rod end.
Honda manual has a picture that shows arm behind swinging arm and outside spring.
Im guessing that Honda changed before end of K1 production?
Will now try re positioning
1977 CB750F1
1977 CB750f1 836
1978 CB750F1
1975 CB500K1
Triumph Street Triple 675R
Ducati 800 Icon Scrambler
Triumph 3TA
AJS 350 mod16
BSA BantamD1
Honda C90zz
Honda CB500X
BSA WD B40 350
Online McCabe-Thiele (Ted)
Re: 1975 CB500 K1 rear brake pedal arm position
« Reply #1 on: April 05, 2024, 11:35:47 AM »
The return spring on my 500 K1 was missing. I eventually sourced the correct return spring for my 500 the spring sits on the outside of the frame/swing arm as you have identified.
There is a photo by Simon (SPR) showing it fitted.
If link works its this:-  http://www.sohc.co.uk/index.php/topic,28739.0.html
« Last Edit: April 05, 2024, 12:48:55 PM by McCabe-Thiele (Ted) »
« Reply #2 on: April 05, 2024, 03:53:14 PM »
All i say is the first thing to fit to the bare frame is therear brake actuator arm, and yes the spring goes on outside
Offline martin_uk
« Reply #3 on: April 05, 2024, 05:44:47 PM »
Thanks Ted
1977 CB750F1
1977 CB750f1 836
1978 CB750F1
1975 CB500K1
Triumph 3TA
AJS 350 mod16
BSA BantamD1
Honda C90zz
Honda CB500X
BSA WD B40 350
