Author Topic: Missing Horn Stay?  (Read 5986 times)
Offline Athame57
    • SeaWitch Artist
Missing Horn Stay?
« on: April 05, 2024, 10:39:57 PM »
I seem to have come across another missing part on my bike, unless it applies to Japanese market only or something?  :-\ I don't have this horn stay on my bike which has the horn forward facing. https://www.yamiya750.com/index.php?main_page=product_info&cPath=179_274_204_240&products_id=3191
Comments?
1978 CB400F2 called Elen.
Re: Missing Horn Stay?
« Reply #1 on: April 05, 2024, 10:57:50 PM »
Its not a horn stay, its a bracket for the loom
Offline Athame57
    • SeaWitch Artist
« Reply #2 on: April 05, 2024, 11:10:49 PM »
I think you mean what they call the 'wiring harness stay? That was also missing, long since replaced ( I opted to paint it myself) If you scroll down the linked page you'll see what I mean by horn stay.
« Reply #3 on: April 05, 2024, 11:12:54 PM »
The link takes me to part 11, listed as wiring. No parts to scroll down to
Offline Athame57
    • SeaWitch Artist
« Reply #4 on: April 05, 2024, 11:39:21 PM »
Also called Stay, horn. Diagram shows it holds horn forward
« Last Edit: April 05, 2024, 11:40:56 PM by Athame57 »
« Reply #5 on: April 06, 2024, 07:51:42 AM »
Only by the thickness of the metal bracket as horn bolts onto same two bolts
Online McCabe-Thiele (Ted)
« Reply #6 on: April 06, 2024, 08:29:59 AM »
My 400 that is a UK bike did not have that bracket plus the cable guide is different as well to the one in your parts diagram.
« Reply #7 on: April 06, 2024, 09:21:10 AM »
Part numbers 11 and 19 were not fitted to the UK bikes. The UK bikes had a flat bracket holding the horn. The bracket has two rubber anti-vibration collars with metal sleeves and is attached to the frame with two long 6mm bolts that also pass through the wire hoop (item 2). The wire hoop acts as a guide for the throttle cables. The bolts also pass through the flange on the frame that in turn forms the front of the frame backbone pressing. The bolts also pass through to what is called the 'speed stay' on the l/h side. The speed stay holds the large diameter rubber boot of the wiring harness in place. The two bolts pass through from left to right so the two flanged nuts are on the horn bracket. If your bike still has the wire loop (item 2) you are very lucky as these were the first items to be lost! You can still buy them from Yamiya. Ash was able to get one for me as part of a larger order (thanks Ash👍).
« Last Edit: April 06, 2024, 09:24:56 AM by Laverda Dave »
1976 Honda 400/4
1978 Honda CB400/4 'Rat' bike
Offline Athame57
    • SeaWitch Artist
« Reply #8 on: April 06, 2024, 09:57:23 AM »
AAHHHH....SSOOOOO!  ;D
