Author Topic: Main Jets 550 F2  (Read 3871 times)
Main Jets 550 F2
« on: April 09, 2024, 12:16:43 AM »
Evening, I’m after a set of #98 and #100 main jets if anybody has any after a re jet et they’ve done.
It’s for Mejima, the 550,  summers coming on and I’ve finally ‘got round to it’ so carbs on the bench and tuning imminent.
I’m struggling to get any this side of the Atlantic and deffo not a set of 4 of each. Stupidly I forgot to get them whilst over in the states last time I was there………..like you do!
Thanks all.
Re: Main Jets 550 F2
« Reply #1 on: April 09, 2024, 03:21:39 PM »
Ok so ordered some #98’s that I’ve found so that’s sorted, just after a set of #100’s if anybody has any?????
They seem to be as rare as unicorn plop but still hoping.
Thanks all
« Reply #2 on: April 09, 2024, 06:30:12 PM »
Considered resizing some ?
https://www.primetools.co.uk/product/stahlwille-11085-jet-reamers/
Reaming is really accurate to finish the bore in brass.
« Reply #3 on: April 09, 2024, 09:43:24 PM »
They are the push in with O rings arnt they mate, if so 100 is atandard 500 so im sure i can find a loner set for you
« Reply #4 on: April 09, 2024, 09:51:23 PM »
That’s right Bryan, they simply aren’t available. I’ve mss as bagged to cobble a set of #98’s via Germany, Lithuania and one from France at great expense and their standards!
If you have mate that  would be bloody fantastic
If they were cheap to start with Nige, I’d invest in a set of reamer’s but for the possible 4 I MIGHT have to do is a bit of an investment I don’t need at the min. Good shout though, hadn’t even considered it tbh.
Offline Moorey
« Reply #5 on: April 09, 2024, 10:20:16 PM »
  Is this the part # you are looking for.  99202-601-1000
« Reply #6 on: April 09, 2024, 10:26:14 PM »
Are there any engineering shops close to you Roo that could ream them for you? I'll be taking a trip to the engineering shop I use soon and I could ask them if you like (cheap postage for four tiny jets!). Although £39 for the set of reamers is probably cheaper than taking them to an engineering shop (and you get another tool for the toolbox!).
1976 Honda 400/4
1978 Honda CB400/4 'Rat' bike
« Reply #7 on: April 10, 2024, 01:11:42 PM »
Yeah, that’s them but struggling to find #100’s for some reason.
Dave, although another tool in the tool chest is all sooper dooper and that, it’s cost prohibitive for me mate on what I need to achieve so as much as I want them being as much of a magpie as I ever was, I’ll keep chasing the jets for now, Bryan said he may have some kicking about so fingers crossed n all that.
Thanks for all the input fella’s appreciate it
« Reply #8 on: April 10, 2024, 01:36:08 PM »
The type of place that would do them to spec is a clock repair business, it's sized right in their trade and experience.
They could likely and easily manufacture a set to spec too from simple brass stock in a small collet lathe. They're often making bushes (very similar in size) to repair old clock plates that have worn spindle holes. All reamed to accurate size in matching the tight tolerance needed.
Set of four aren't really much work in total labour time.
Could be an avenue to explore, perhaps if someone else needed some decent quality too.
« Reply #9 on: April 10, 2024, 01:39:03 PM »
Matt Harrington is a clock restorer and has all the gear to do microscopic twiddles, that’s a good shout, I’m due down to have a yap n a brew so I’ll mention it to him. Good thinking Nige
« Reply #10 on: April 10, 2024, 05:12:56 PM »
 ;D bonus.
Certainly worth talking it through with him, may be able to help out.
« Reply #11 on: April 10, 2024, 07:41:46 PM »
Roo, i have several sets of 500 carbs about and will get some out on saturday for you to borrow mate
Offline Moorey
« Reply #12 on: April 10, 2024, 07:47:40 PM »
 A bit of a long shot but they were used in Honda mowers. Could be worth a call as mowers are taken in every spring for a service because they won't start.
Offline ozzybud
« Reply #13 on: April 10, 2024, 09:22:17 PM »
1976 Z50 YELLOW
1970 CT70 BLUE
1971 CT70H ORANGE
1972 CT70H GREEN
1973 CL200 BLUE
1975 CB360T RED
1975 CB400F BLUE
1975 CB550 ORANGE
1976 CB750F RED
