Author Topic: CB500K1 1975 Neutral rotor & contacts , primary driven sprocket, main jet holder  (Read 1609 times)
Offline martin_uk
If anyone has the above available would be interested in buying.
A complete primary shaft would be ok as long as sprocket teeth are ok
Its the spring plate that holds main jet.
Let me know price and condition.
Martin
1977 CB750F1
1977 CB750f1 836
1978 CB750F1
1975 CB500K1
Triumph Street Triple 675R
Ducati 800 Icon Scrambler
Triumph 3TA
AJS 350 mod16
BSA BantamD1
Honda C90zz
Honda CB500X
BSA WD B40 350
Those Neutral switches  are like Dodo Eggs to find.
I have the spring contact part only but the tip is broken off it still worked though!
I believe Nurse Julie knew someone who repaired them at one time if you have an original worn or broken part..
Online Bryanj
I ccan do you a nos rotor and the main jet leaf springs do appear on a US website when in stock but only in sets of 4, stainless and not cheap.
Can pprobably find a used spring
 But these and the rotors are now like hens teeth so not cheap pm me if interested.
Ask nurse Julie if Trigger has any of the stator contacts left he had etched a long while ago.
Do you mean the primary chain sprocket on the shaft? Never seen one worn
« Last Edit: April 17, 2024, 01:41:24 PM by Bryanj »
