Author Topic: Plugs fouling at idle  (Read 18391 times)
Re: Plugs fouling at idle
« Reply #15 on: April 25, 2024, 12:22:47 PM »
Another observation, the Boyer ignition is very, very competent in it's delivery. I've no problem working with the std system, believing it to be mechanically almost peerless in it's design, application and component specification .... the Boyer i can see by comparison does offer tangible benefits if that's chosen by the owner though.
Among those benefit appears the ability to fire more adverse mixture range more of the time with exceptional repeatability.  This seems to support a more optimum idle mixture that may give benefit in any residual unburnt component/fuel that may be affecting the fouling determination this topic is about.
The advantage you attribute to B#B, is valid for any EI that has a transitor doing the switching. Realise that even in stock configuration, coils will be fully saturated. Only in border situations a transistor has the advantage of more reserve as there's no loss due to mechanical breakers (tiny sparks can be seen in stock set up). The steeper rise time a transistor ignition provides, will also offer some reserve in border situations. That's all to it, I'm afraid. There's no shortage of spark duration because @ idle initial peak voltage will be relatively low (estimation around 7kV). An EI will NOT give a higher voltage. Why should it, if the circumstances are thus, that already 7kV is enough to bridge the plug gap. Ergo: lots of energy available.
It's the gap that determines a higher or lower initial peak voltage and the atmospheric circumstances in the combustion chamber ofcourse.
In my personal situation, I'm experimenting (you guys know me ;)) by following what is advised in a American Honda booklet. Needles are now raised one notch (and thus in 4th) and the airscrews are two turns out.
Here is something I have never communicated before. In the very first year I owned my CB500 (1980), I travelled as far as Greece. On a camping in the Peloponnessus I decided to open the Haynes manual. Being completely ignorant I followed the data in forsaid manual and have set the airscrews at one turn out. To this day I wish I had never touched them. I should at least have made a note what they were in before. Immediately the next day I noticed a difference: a negative one and never thereafter in 44 years have I been able to regain that perfect utterly smoothly accelerating CB500 again. Don't take me wrong. It has always been good thereafter, but never so perfectly accelerating as before. Later the properties of gasolines changed which made it even more difficult. That's why I am always curious to know what position other CB500 owners have their airscrews in. If my plugs stay clean at idle, driveability in acceleration suffers. My understanding is that even 1/8 of a turn can make a big difference and at least one Honda mechanic has told me that the position of the airscrews of all 4 can individually differ in position more than just 1/4 of a turn. Soon I hope to use my restaurated CO gas analyzer and see what an initial 4% CO at idle will bring.
« Last Edit: April 25, 2024, 12:27:20 PM by deltarider »
« Reply #16 on: April 25, 2024, 01:44:15 PM »
You're making the assumption that I've said it needs more power (supplied by the Boyer ? ) which is not what I've stated.
I agree it doesn't, there's other attributes within that system that hold value in this performance arena.
Question .... can you describe the failure mode within the combustion chamber which gives erratic acceleration response as you've described it ? In other words, why are you not getting a perfectly linear response with the settings you have.
Honda never state (as far as I appreciate) that you have to use equal idle circuit settings, just a suggested start point, from which their setup routine .... well written in my view ..... will allow settings for individual cylinders in giving long term combustion equality. Thats just normal in my reading of their factory instructions.  It goes further in the later PD carbs, such that it calls for correct settings, then to record those individual adjustment as the genuine reference point from then onwards.
Also it states that they are set in this way at factory, advises not to arbitrarily adjust them without making good record of their factory position BEFORE working on them.
Sensible, I feel.
« Reply #17 on: April 25, 2024, 08:07:04 PM »
Sorry if I did. I may have been misled by what so many believe who attribute super powers to an EI. You have shown far more knowledge. The ignition in itself is quite an ordinary process. Complicated is that we deal with 1) an idle, 2) load (acceleration) and 3) cruise.
I wouldn't call it erratic. Before I touched the airscrews in 1980, acceleration was just fabulous. In my memory I was constantly turning the throttle grip forward to prevent the bike from leaping like a jaguar. Later it was just good. The mec that initially has tuned my bike - either in Japan or in Holland - must have done a perfect job. Later a Honda mec - not the same - learned me that airscrew positions may need to differ further than just the +/- 1/8 of a turn Honda prescribes. BTW, in his years long experience the CB500 was the hardest to fine tune of all the CB Fours. This could relate to the special carburetor setting, models for the European continent had. I don't know. Not much later after my trip to Greece, gasoline quality changed dramatically. I remember having read an article by a widely respected professional writer for automotive and motorcycle mags - who himself owned a CB550K3 - in which article he concluded in his last line (in despair?) that "some motorcycles just don't like some gasolines". I have never asked him, but he himself may have been struggling with his CB550K3, after the arrival of the changed gasolines.
Honda never state (as far as I appreciate) that you have to use equal idle circuit settings, just a suggested start point, [...]
I didn't say Honda did, but Honda did give a range of +/- 1/8 of a turn. Some mechanics judged the difference in air screw position amongst the 4 could need to be more than that. I suppose they may have had a reason for that.
Offline davidcumbria
« Reply #18 on: April 26, 2024, 06:28:43 AM »
Interesting thread. This fouling at idle - is this when the revs drop after running steadily for 20 seconds and can be cleared by revving the throttle to restablish the steady idle?  Mine does have that tendency on the denso plugs but also one cylinder which is cooler than the others so I’m guessing that’s the one that fouls.
I have found on many different bikes cars  lawnmowers-that iridium plugs give better starting, smoother idle  and avoid fouling on two strokes.  It seems there isn’t one available for the 550 - why not ?
500/4 in 79. No bikes for 30 years. 750/4 in 2013, 550/4 in 2023. Also own  R1100GS, RD350LC YPVS , Triumph Street Triple, Yamaha XT250
« Reply #19 on: April 26, 2024, 09:26:13 AM »
Think I'd initially swap the plug lead with it's paired one to see if the cool running transfers with that lead. If it stays where it was, then looking more at that cylinder condition, compression analysis to count that out, idle jet system to ascertain if there's any impairment.
« Reply #20 on: April 26, 2024, 09:42:10 AM »
If there's response by swapping the leads over (within one  oil pack) then analysis of why that could happen may give answer.
There's specific performance in the condenser relating to this (if the original system is in place) with it's ability to fire the mixture.
The opposite ends of the coil have slightly different spark characteristics,  with also the condition in cylinder from the live one to the wasted spark one maybe causing a bias to disadvantage the live cylinder on compression and give a shift in performance to that cylinder.
Swapping the leads checks for that, also the insulation of the HT too.
« Reply #21 on: April 26, 2024, 03:38:25 PM »
On second thoughts... I may have exagerated a bit. Fouling happens when there has been excessive idling: too many times for extended periods of time. I have made it a habit when bike idles too long, due to traffic, to rev briefly every minute or so. When idling for >15 minutes, without revving at least once, I can not expect plugs to stay deer brown.
« Reply #22 on: April 26, 2024, 04:03:57 PM »
My understanding of spark plug technology  is they are designed to be  self cleaning at higher revs/temperatures - obviously there is a limit to this function so if the mixture is overly rich right through the range they will soot up.
I suspect throttle blipping was something we used to do to keep the plugs from sooting up at idle to make a clean getaway.
My experience primarily with cars using carbs is that a vehicle used for mostly short journey work fitted with the manufacturers standard plugs would foul up badly needing a good run to clear the carbon deposits.
I particularly remember a disabled customer who ran an Automatic Opel Commodore 2.5 GS (1974) from his home to work a  distance of less than a mile. On collecting his Opel from Ashbourne it would not exceeed 45-50 mph flat out. During the course of the journey to our service department  in Burton the top speed would slowly improve until it would reach 60-65 mph. After a service the car would drive like it should for a 2.5 litre straight six.
Fitting a different plug type to cope with the short journey used mostly on auto choke was not an option as the customer would drive to Scotland a few times a year where he had family. In reality he wouid have been better driving a car with a much smaller engine.
« Last Edit: April 26, 2024, 04:38:09 PM by McCabe-Thiele (Ted) »
« Reply #23 on: April 26, 2024, 04:44:46 PM »
Unfortunately I haven't been riding like in the past: looooong stretches >130km/h uninterupted on motorways. It was always great how well the engine responded afterwards.
« Reply #24 on: April 26, 2024, 05:19:06 PM »
Could I suggest something I do,
Take the bike for a run   about 15 to 20 miles  get it nice and warm
When home, keep the engine running, put on centre stand
Get your long screw driver
Now ,turn one airscrew a quarter turn out,
Check what happens, blip the throttle, OK?
If it struggles,turn to previous settings
But if its OK,do another, repeat, and check
Remember, Modern fuel is different than 50years ago,
It might like a leaner tickover
« Reply #25 on: April 26, 2024, 09:03:47 PM »
I'll put it out there, plug fouling can also be caused by oil burning.
Worn rings or valve stem seals/ guide wear.
« Reply #26 on: April 26, 2024, 09:58:31 PM »
It's not oil. I smell petrol so it's overrich. Fuel is different these days. Maybe Shell is right and you can adjust to leaner and save fuel when you run their V-power, which I do. The problem with these bikes is, they will always run and keep going where a twin simply quits rightaway when something is not in good order.
« Reply #27 on: April 26, 2024, 11:13:30 PM »
Is it possible that you smell unburnt petrol as the oil has fouled up the plugs first - cause oil deposits on the plugs leading to unburnt petrol afterwards. Often you can see no blue smoke in oil burners.
Where rings have been replaced rather than a rebore with some glaze breaking  I suspect some running in might be needed before worring about  plug colours.
As an aside my 400 that was rebored by Graham has only covered some 230 odd miles - unless it starts misfiring I will not check the plug colours until it has covered about 600 miles. My idle speed is good and even - to date only bench synched the carbs as it's now running so well after my initial mistake on the plug connections when it was a two cylinder bike for a while!
« Reply #28 on: April 27, 2024, 06:59:28 AM »
For me the question is formost: can I indeed compensate the needles clip in 4th groove by adjusting the air screws to two turns out, like that American Honda specifications booklet suggests or should i return to the European set up with needles clip in 3rd? I have always had my doubts about that US booklet and I therefore volonteered to experiment.
« Reply #29 on: April 27, 2024, 08:04:26 AM »
Thanks. the leads on my bike are very stiff. I’ve remade the cap connections but I’m not very happy with them. Definitely thinking of doing the Ash fix. On the other hand it starts well and has no high Rev mis fires which makes me think ignition is ok. I can live with the slight tendency to idle foul and my air screws are out  more than 1.5 turns from memory running on shell e5. I’ve improved no 1 cylinder running cool by installing #35 pilot jet and overall the bike runs very well.
