Try our new info resource - "Aladdin's Cave" (Main menu)Just added a separate link to Ash's Dropbox thread (shortcut)
Ted, thank you 🙂 how many turns out are your mixture screws?⁹
Just thought I'd ask my floats are at 22mm and it's running very rich, I have Hendler carb kits on the way as I suspect a wire has been used to clear the jets....can anyone please confirm the float height...
Quote from: Honda enthusiast on April 29, 2024, 08:04:33 PMJust thought I'd ask my floats are at 22mm and it's running very rich, I have Hendler carb kits on the way as I suspect a wire has been used to clear the jets....can anyone please confirm the float height...You may want to double check your measurement first, by applying this method: http://forums.sohc4.net/index.php/topic,185754.msg2151647.html#msg2151647I measured 50ml exactly but I wouldn't worry if you measure 2ml more or less.
