Author Topic: Relocating or alternative to ignition switch  (Read 769 times)
Offline DomP
Re: Relocating or alternative to ignition switch
« Reply #15 on: May 14, 2024, 04:42:46 PM »
Sorry to hear about your sister Bryan.
I may make up a bracket and utilise the horn fixing points
1975 XS650B
1976 CB550F1 current project
2012 Triumph Daytona 675
« Reply #16 on: May 14, 2024, 04:52:54 PM »
Sorry to hear that Bryan, best wishes mate.
« Reply #17 on: May 14, 2024, 04:54:22 PM »
I know where there might be some brackets but they’re in the US.
Do you want me to ask my pal over there Dom? It’s a bit of a long shot but I know they’re there……
Offline DomP
« Reply #18 on: May 14, 2024, 05:27:16 PM »
Don't worry Roo, I'll cobble something up on the cheap if I can, failing that I'll take you up on your kind offer mate
1975 XS650B
« Reply #19 on: May 14, 2024, 05:30:04 PM »
No worries bud, just shout Dom
Offline DomP
« Reply #20 on: May 14, 2024, 08:24:17 PM »
This is the 550F wiring diagram, the two browns connect pretty much immediately in the loom anyway so surely eliminating one or rejoining them will make no difference on a 4 wire switch?  Isn't it just the park position
1975 XS650B
« Reply #21 on: May 14, 2024, 08:42:28 PM »
Got it, the only reason for the extra brown is the fact the steering lock is on the ignition switch so you need to feed the sidelights from there, just joining both to the one brown on the 4 wire will be fine as it does not have a steering lock built in.
I would suggest a padded P clamp on the frame tube holding the bracket the switch fits in.
Offline DomP
« Reply #22 on: May 14, 2024, 08:45:26 PM »
Perfect Bryan, could I just eliminate the spliced in brown then?
1975 XS650B
« Reply #23 on: May 14, 2024, 08:47:47 PM »
Yuo
