Is is possible to replace the kickstarter shaft (complete) without disturbing anything else in the crankcase?
I am sure that my kickstart does not work because the splines on the shaft are stripped. I have the kickstart lever attached so I have not fully investigated this yet. Even so, I may only need the knuckle end if the lever is the issue and not the shaft.
I am inclined to do nothing if the shaft repair is required and necessitates any work that dismantles the crank case. I would like a fully working kickstarter just for fun.
