Author Topic: Wiring  (Read 266 times)
Offline Madgrandad
Wiring
« on: May 23, 2024, 03:14:47 PM »
Hi all,
I'm restoring a 1978 CB400 4F and I'm onto the wiring. The previous owner botched up the wires by using any colour, I have put it back to original colours as per manual. My question is I can see how the rear indicators are earthed but can't see how the front is earthed? Manual shows Light blue / green on right hand side and orange and green on left hand side, I only have one wire coming from each indicator?
Does anyone who owns same model live near Southport, Merseyside so I could have a look?
Thanks in advance ☺️
Re: Wiring
« Reply #1 on: May 23, 2024, 03:21:07 PM »
If memory serves me correctly the front indicators are earthed via the main mounting stem that is metal.
Inside the headlamp on each side is an earthing plate that is connected into the wiring loom earths.
I fitted the chromed plastic ones fitting my own earth wire to the bulb holder threading down the hollow centre.
If you look in the parts book (downoadable here) it is shown in detail. Personally I like fitting an additional earth wire to all four indicators.
« Last Edit: May 23, 2024, 03:29:42 PM by McCabe-Thiele (Ted) »
Online Laverda Dave
Re: Wiring
« Reply #2 on: May 23, 2024, 03:29:04 PM »
Spot on Ted.  The rear indicators are earthed via a cable connector onto the tang welded onto the indicator mountings.
1976 Honda 400/4
1978 Honda CB400/4 'Rat' bike
Re: Wiring
« Reply #3 on: May 23, 2024, 03:32:21 PM »
My rear tangs were rotted out, a PO had drilled a hole in the mounting bracket with a screw fitted to one, hence I fitted seperate earths.
Offline Madgrandad
Re: Wiring
« Reply #4 on: May 23, 2024, 05:15:06 PM »
Ted, so what your saying I have to solder a green earth wire to the inside of the indicator earthing plate and run that to the loom?
Re: Wiring
« Reply #5 on: May 23, 2024, 05:58:59 PM »
If I remember correctly I drilled a small hole on the bulb holder plate  then screwed a wire to the plate via an eye connector.
I might have used a small pop rivett it was a couple of years ago.  Then as you say ran the wire inside the front headlamp cross tube and into the headlamp bowl to the earth terminal that acts like a captive nut holder for the headlamp fitting side bolt.
Offline Madgrandad
Re: Wiring
« Reply #6 on: May 23, 2024, 07:43:33 PM »
Yes that's what I thought. Thanks for your help Ted 👍
