Author Topic: Oil pump O rings / cylinder head gasket seals  (Read 2637 times)
« on: October 13, 2010, 11:19:31 AM »
Hi,
I am sourcing 'O' rings to rebuild two Oil pumps I have. Are the originals Viton or Nitrile? If Nitrile are they 70 Shore A hardness?
( I am getting the small oil seal from David Silvers (the GoldWing type - Thanks for the info Bryan  !!) but the 15x2 AND 46 X 2 'O' rings are really expensive from Honda
Also I think the o rings to use a later head gasket on a non-knock pin K0 sandcast head are 14 ID x 1.5mm thick (Viton) Can anyone confirm this please?  Would a 'quad' ring be better, as I gather the unobtainium ones in the Honda bulletin were square section
Cheers !!! Ash
Offline leadnavel
Re: Oil pump O rings / cylinder head gasket seals
« Reply #1 on: November 28, 2021, 12:13:56 AM »
I’m rebuilding the pump on my 750K7 but cannot get the small seal as it’s been discontinued! I would be interested in the part number for Goldwing small seal that you mentioned that would do the job Ash.
CB750K7
« Reply #2 on: November 28, 2021, 04:12:14 PM »
Hasn't Julie got what you need Ash, she has millions of sizes of the Viton ones in stock for various oil pump rebuilds?
Offline leadnavel
« Reply #3 on: November 29, 2021, 12:20:10 PM »
Thanks Laverdaroo I have contacted Nurse Julie who is kindly sending me ‘O’ rings and seals for my K7 oil pump rebuild.
CB750K7
« Reply #4 on: November 29, 2021, 06:52:11 PM »
nice one 8)
