Author Topic: Vale spring compressor - recommendations  (Read 3267 times)
« on: January 02, 2011, 06:29:19 PM »
Does anyone have a valve spring compressor that they would recommend (for use on a CB engine)? I'm not quite sure what I'm looking for but I've seen a model by Sealey for c.
Offline totty
Re: Vale spring compressor - recommendations
« Reply #1 on: January 02, 2011, 06:37:10 PM »
I've got the same set, never used it on a CB but it was adjustable enough to use on both a z50 and a 3.0L Essex v6.
Offline matthewmosse
« Reply #2 on: January 03, 2011, 11:25:25 AM »
« Reply #3 on: January 03, 2011, 11:31:29 AM »
Cheers all. Last night I used the weight arm from an old set of scales (think the giant ones used to weght sacks of corn), pivoting in the vice and pressing down on a piece of steel tube - with slots cut in it to allow me reach the collets.
Good advice on the magnetic tools / grease. I was wondering how easy they could be to get back in.
Offline Dave M
« Reply #4 on: January 06, 2011, 10:52:47 PM »
The grease and screwdriver works fine on a C50 too!
Dave
Melbourne.
Offline Seamus
« Reply #5 on: January 10, 2011, 10:28:58 PM »
Had a Sykes Pickavant adjustable unit for years now and used it on car and bike heads for at least 10 years.
I will post a picture if it is any use
Offline Yoshi823
  • Biker to the bone...
« Reply #6 on: January 27, 2011, 03:02:56 PM »
I still have my valve spring compressor from 1975 when I bought my first bike. I paid
Bikes...they're in the blood.
Yamaha R1 2001
Yamaha FZR1000R EXUP 1990
KTM 450 EXC RFS 2004
Honda XR400R 1997
Honda CB125T2 1980
Yamaha FJ1200 3XW 1991
Offline UKROBK7
« Reply #7 on: January 31, 2011, 08:31:20 AM »
I use the same one as that on ebay but I picked it up at the Stafford show for
« Reply #8 on: January 31, 2011, 06:39:19 PM »
Thanks for the replies. I've now taken them all out & put them all back in succesfully without losing any collets. I used the G-spring method with long nose pliers & grease. Pliers were tricky to use so backed them up with a nail-file...the magnetic screwdriver helped but I found pliers / nail file easier. It sounds as if tweezers could be an even better route.wasn't ideal but did assist me.
It took a me little while, not least as I did the first one about four times over to get it right. Learning point #1-don't miss the large spring seat/washer out. Learning point #2-when you take the assembly apart to put the large spring seat in, don't let the small spring seat/washer fall out unnoticed.
« Reply #9 on: February 01, 2011, 06:21:30 AM »
Andy, dont fret it, ijust rebuilt a 500 for a member in the north and the bits that were missing from a PO, plus the goo everywhere were frightening mate
« Reply #10 on: February 01, 2011, 10:16:55 PM »
I have a large stockpile of collets, seats and so fourth, even the most dud engine can relinquish good parts - most extreme example was an engine I bought on which all the lower cases had corroded past use and internally full of mud - gearbox was full of rust and eventually I knocked the bottom end appart with a hammer as the selector forks and drum were fused solid, the head was however prestine under all the oily sludgy mud that it was full of.
