Author Topic: Is my f2 charging properly  (Read 1213 times)
Offline UK Pete
« on: February 18, 2011, 06:10:53 PM »
Is there an easy way of telling wether my f2 is charging properly or even charging atall ?
Pete
Re: Is my f2 charging properly
« Reply #1 on: February 18, 2011, 06:47:00 PM »
Hi Pete, sounds like your having fun!!
Quick and dirty with no kit is to run it with headlight on at slow tickover in the dark and when you get it above 2000rpm or so it  should be brighter, if not it's usually not charging.
Same thing with meter across battery should rise from about 12.5volts not running to max 14 as revs come up, should have peaked by about 3000rpm I think.
Nigel.
« Reply #2 on: February 18, 2011, 06:55:02 PM »
Here's the (not) quick and dirty explanation:
http://www.sohc4.net/index.php/archives/50
and here are the battery terminal voltages to expect:
http://www.sohc4.net/index.php/archives/137
2022 Tiger Sport 660
Offline Yoshi823
  • Biker to the bone...
« Reply #3 on: February 19, 2011, 09:22:25 PM »
Pete...if you suspect the windings, rectifier or the regulator I can test them electrically as I have the right equipment.
Bikes...they're in the blood.
Yamaha R1 2001
Yamaha FZR1000R EXUP 1990
KTM 450 EXC RFS 2004
Honda XR400R 1997
Honda CB125T2 1980
Yamaha FJ1200 3XW 1991
« Reply #4 on: February 20, 2011, 11:38:15 AM »
Windings, i have never seen go wrong EXCEPT for impact damage, regulator points have been known to stick, rectifiers only normally go wrong if you let the smoke out by connecting a battery backwards---although i have seen some so corroded the wire has fell off.
Normal problem is dirty/bad connectors
PS dont forget the F2 can standard with a halogen headlamp so the revs to charge are higher
