Author Topic: 3 cylinder 550  (Read 7837 times)
Re: 3 cylinder 550
« Reply #30 on: April 25, 2011, 08:12:29 PM »
Have you ridden it to see if it runs on all 4 when brought up quite a bit from idle jet circuit or is it still not getting the pipe on #2 hot? if it runs out ok this would suggest idle jet circuit part blocked.
On some bikes you can swop the wiring and HT leads round to see if the problem goes with one coil and at least isolate 50% of the resoning. May have to unbolt the coils to make things reach.
Online mickwinf
Re: 3 cylinder 550
« Reply #31 on: April 26, 2011, 08:47:00 PM »
i am thinking it is fuel rather than electrics, but can't ride it yet as not on the road,will probably have to take carbs off again and clean out, again!
