Author Topic: Rear wheel size  (Read 1403 times)
Offline Paull
Rear wheel size
« on: April 24, 2011, 04:37:22 PM »
My CB550 f2 has a 16ins wheel with a 120/90 tyre on it, what differents will this make over the standard 18ins wheel, the bike is now far from standard.
Paul
S**t Happens
Re: Rear wheel size
« Reply #1 on: April 25, 2011, 04:30:01 PM »
Except for the fact it won't fit in a standard mudguard not a lot
Re: Rear wheel size
« Reply #2 on: April 25, 2011, 08:40:10 PM »
I work it out like this to get overall diameter of wheel/tyre; (thinks it's correct but please add if not)
Tyre width is 120mm and distance from rim to tread is 90% of this hence the marking 120/90.
So you can go 16 inches in mm then add 2x the above calculation to get overall diameter of assembly.
Do the same for the original spec to compare.
