Author Topic: Smoking  (Read 3100 times)
Offline Octavian
Smoking
« on: June 12, 2011, 03:32:07 PM »
Hi, so I put in a new wiring loom over the winter, sorted out timing, cleaned the carbs, bought some new plugs and fired her up.
It took a few cranks and a bit of tweaking of choke & throttle but she finally bubbled into life.  To be fair she rattled like my grans knees, but worse.. the smoke.  White smoke puffing constantly even after 10 minutes of idling and smelling of heavy petrol fumes.
She's not been on the road for about 5 years, any thoughts insights to what this might be?  Could it be moisture, condensation, or worse than that.... valves and pistons?
I would be grateful if someone could provide some easy checks to isolate the potential probs.
Cheers guys.
1977 CB400/4
Re: Smoking
« Reply #1 on: June 13, 2011, 06:24:13 AM »
If it smaells of petrol it could be unburnt fuel and the causes of that are myriad
470four
Re: Smoking
« Reply #2 on: June 14, 2011, 09:50:57 AM »
Firing on all four? Carb floats free to move?
I did think sticking piston rings but that would be blue smoke...
Re: Smoking
« Reply #3 on: June 14, 2011, 08:20:07 PM »
Did you change the oil after sitting all that time?
If it runs without any obvious problems then you'd need to get it quite hot to make sure any oil/fuel that has got to the wrong place would be expelled fully. Thinking more of valve guide seals if they have leaked while standing then the pistons/combustion chambers can be coated and will burn off. If that was the case then you'd expect it to clear and not happen again after another cold start.
Offline Octavian
Re: Smoking
« Reply #4 on: June 18, 2011, 11:38:58 AM »
Hi guys, sorry for the delay in responding - I have been in France all week.
Its definitely not blue smoke, all cylinders are firing as far as I can tell - no misfiring, and when I cleaned each carb the floats were loose enough on the pins.  The old oil was cleaned out and replaced last year and when checked before starting the oil on the dipstick appeared clean/transluscent.
I only ran it for maybe 10 minutes at most 3 or 4 times over the course of 3/4 hours - I didn't want all the neighbours running around screaming about pollution!  Hopefully it is just burning off old gunk.
1977 CB400/4
Offline Octavian
Re: Smoking
« Reply #5 on: June 26, 2011, 04:37:58 PM »
Ok, so since posting I have changed the oil, stripped and cleaned out all the carbs and flushed the tank out and put clean fuel in and started her up.  Cough splutter, cough splutter, still loads of smoke.  I'm starting to think its blue smoke now.  >:(
1977 CB400/4
Offline Octavian
Re: Smoking
« Reply #6 on: July 04, 2011, 02:03:14 PM »
So, can anyone offer any further advice to assist me isolating the problem ?
I have run a compression test and all plugs show a slight improvement when I drop some oil in, suggesting piston rings could be the issue.  So whats my best bet, strip her down and do the rings or is there anything else I should check out before committing myself to that?
1977 CB400/4
Re: Smoking
« Reply #7 on: July 04, 2011, 02:23:05 PM »
OK what is the history of the bike, was it running well before it was laid up ?
Is the air filter clean, is the exhaust standard, have you checked the points/timing/advance & retard unit, what colour and condition are the plugs, are the HT leads in good condition (and plug caps). Carbs all clean and float levels correct ?
Just a few ideas.
Den
Re: Smoking
« Reply #8 on: July 04, 2011, 09:59:41 PM »
If you suspect the rings it could give the characteristics you describe and would improve with oil to help it seal when you test it.
What psi reading did you get and what did it improve to?
If that is so, I would try to see if they are just stuck from sitting for a long time by doing this:- make sure that the head gasket surface is level (think it's barrel is upright on 400-4) and remove the plugs. Turn the crank to get the pistons all roughly level and spray a decent amount of WD40 or PlusGas into each cylinder enough to fill the ring gaps around each piston with liquid and leave it overnight then spin it over with the plugs in as this tries to force the compression rings into making a better seal, repeat for another dose and then try to run it.
If you still don't get good readings then you maybe forced to strip the top-end to have a better look.
470four
Re: Smoking
« Reply #9 on: August 07, 2011, 01:04:40 PM »
My Four piston I removed just after getting the bike some 21 years ago?
I remember reading if they are continually redlined the rings break & make a bid for freedom... needless to say it smoked a tad.  :)
